A-Pillar Pod Install & Pics :D
Old Mar 27, 2004 | 05:28 PM
allmotor_2000's Avatar
Enjoy!!
http://f1.pg.photos.yahoo.com/ph/gun...&.dnm=3fd6.jpg
It's not the greatest install... because these don't have the clips and you have to drill into the A-pillar - plus the screws they give are too short!
Old Mar 27, 2004 | 05:31 PM
mattg's Avatar
so how long until they are useful?
Old Mar 27, 2004 | 05:57 PM
AK_MOBBER's Avatar
VOTE OUT THE BUSH REGIME
looking good. Can't wait to hear about your progress.
Old Mar 27, 2004 | 06:03 PM
Haha... I am still figuring that out! . It will be at least a month or so.
Old Mar 27, 2004 | 07:03 PM
scalbert's Avatar
So how is it that I started this whole thing coming up on a year ago. Live closer to the shop than most. And I haven't received mine...
Old Mar 27, 2004 | 07:05 PM
scalbert's Avatar
BTW, looks great Ramanan.
Old Mar 27, 2004 | 07:06 PM
Red-CL's Avatar
Doin' da crack shuffle
Nice
Old Mar 27, 2004 | 07:57 PM
18anatak's Avatar
Looks good.
Old Mar 27, 2004 | 10:43 PM
Red Rider's Avatar
Subie Dubie
Me Liikee
Old Mar 27, 2004 | 10:48 PM
TranceFusion's Avatar
looking good...
Old Mar 27, 2004 | 11:21 PM
liloj's Avatar
i like orange juice
nice
Old Mar 28, 2004 | 12:58 AM
mantis23's Avatar
Moderator Alumnus
phat
Old Mar 28, 2004 | 08:56 AM
JaDia4's Avatar
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
looks very clean. congrats.
Old Mar 28, 2004 | 09:54 AM
NSXNEXT's Avatar
Wow Those Works look sweet on the NSX
http://us.f1.yahoofs.com/users/5f60a...7ovZAB0tvtZhD6
Old Mar 28, 2004 | 10:33 AM
Essarak Huot's Avatar
Re: A-Pillar Pod Install & Pics :D
Originally posted by allmotor_2000
Enjoy!!
Hey I'm wondering if the gauge pillar match the oem interior? I just got mine in and it doesen't look like it matches
Old Mar 28, 2004 | 12:55 PM
darrinb's Avatar
///M POWER
lookin good, should be a swet ride when ya get the turbo on
Old Mar 28, 2004 | 02:07 PM
Re: Re: A-Pillar Pod Install & Pics :D
I painted mine... so they match perfectly!! I don't think its worth the $50, but hey, its a monopoly and nobody else makes it!
Old Mar 28, 2004 | 02:12 PM
Smitty's Avatar
link does not work...
Old Mar 28, 2004 | 02:15 PM
Chopsie's Avatar
Beware of leakage
I wanted to see this, may be a problem with yahoo.
Old Mar 28, 2004 | 03:22 PM
Smitty's Avatar
Well why wait when you can see my install.
Thread Hijack!!..
I got this done this morning before I detailed the whip.
Enjoy
Old Mar 28, 2004 | 03:28 PM
Smitty's Avatar
Installation made easy:...
I recommend 2 things:... Make sure you drill the holes STRAIGHT, if the flat head screw (you will need to purchase since the ones they give you are too short like Allmotor said) does not go flush with the pre-drilled pod hole then the end cap that you place over the screw will look retarded and cocked.
Take all sticker off the base of the gauges with goo gone because the pods are a tight fit... I used some hand soap on the base of the gauges so they installed alot easier...
P.S. Make sure you put them in straight after you install the pod and it is secured to the A-pillar.. you get 1 shot at it or you got to take the pod off the A=pillar and push the gauges out from the back to get them out...
Old Mar 28, 2004 | 03:30 PM
Smitty's Avatar
P.S.S. I took the tint off the lower part of the winshield for those of you who did not notice in the pictures above...
looks alot better without it... thanks for the advise fellas..
Old Mar 28, 2004 | 03:34 PM
Crazy Bimmer's Avatar
i want one!
Old Mar 28, 2004 | 04:24 PM
Chaptorial's Avatar
Wow super clean install on both of those. We need some vids of them in action however.
Old Mar 28, 2004 | 05:06 PM
For the electronic boost guage, where did you get power from? It needs switched power that stays on during cranking - I found one spot, but for some reason appears intermittent?!?
Old Mar 28, 2004 | 05:08 PM
Scrib's Avatar
Administrator Alumnus
Damn.... Jealousy is such a bitch!
Looks GREAT!
Old Mar 28, 2004 | 08:46 PM
Smitty's Avatar
Hmm let me think... I can not quite remember if it was fuse #11, I will look when I get my shock sensors in Monday or Tuesday and report back.
Old Mar 28, 2004 | 08:52 PM
What do you mean fuse? You wrap wire to the fuse!?! I have it to a +12V source that doesn't turn off during cranking, but the damn thing is very intermittent and doesn't turn on sometimes!
Old Mar 28, 2004 | 08:53 PM
Smitty's Avatar
I think I tapped into the Black wire with the silver stripe that goes to the Moon roof, Jens told me it is HOT at all times.. I will check into it and report back
Old Mar 28, 2004 | 08:54 PM
Thanks!
Old Mar 29, 2004 | 09:00 AM
fuzzy02CLS's Avatar
I got mine Saturday. Have no use for it anymore. But I'll keep it. What size gauges would I need? & what type is best?
Old Mar 30, 2004 | 02:49 PM
ModAddict's Avatar
Yes, I used one of the fuses on the drivers side fuse panel to power the boost gauge. It was one that stayed hot while cranking as you say, but I don't recall which fuse it was. It might have been the fuel pump.
The lighting power, which I never did get around to doing, would allow the gauge lights to turn on and off, and dim with, the rest of the gauges on the dash. This is where I got the info for that from. Note that the red/black Jens refers to, Smitty actually found to be red with gray dots.
Jens H. wrote on 08-06-2003 12:06 PM:
….., if you want to connect your autometer gauges it is easy .For ease of access you can use any switch such as the moonroof VSA or foglamp switch .Remove the switch and you will see that each has a red/black wire in it this will be the power source for your light in each gauge ,then locate the red wire ,this will be the ground source for your lighting .Connecting it this way will allow you to use the dimmer circuit on your gauges .I do not think this will cause any problems for the dimmer circuit but I cannot guarantee this .So you will be in somewhat uncharted water on this .The dimmer is actually a small computer that controls the ground side of the lighting circuit.The rheostat is only a control for this small computer.
Please make certain all of your connections are well insulated to avoid any problems .Attach one gauge at a time to this ciurcuit and verify that everything else on the lighting circuit is still working normally as I do not know how many liughts can be added to thiss circuit safely but I think yu should be ok.
RED/BLACK is power source
RED is ground
Please remember this is for LIGHTING only it is not a valid ground for anything else .
Jens
Old Mar 30, 2004 | 02:51 PM
Smitty's Avatar
ahhh... .. thanks Brad.. I knew I could count on you..
Theres your answer Allmotor..
Old Mar 30, 2004 | 02:58 PM
trancegemini19's Avatar
what size screws to you buy to replace the short ones lotek gave us?
Old Mar 30, 2004 | 03:12 PM
Smitty's Avatar
I used FLAT/FLUSH Phillip headed 1-1/4 inch.
Only need 2 so get the 1-1/2 to be on the safe side just incase... I am sure everyone is going to have different fitment issues arise.
Old Mar 30, 2004 | 04:50 PM
I got it working... basically it needed a beefier voltage source - I had it hooked up to a pretty wimpy one I suppose.
Looks fine... works fine
Thanks!
Old Mar 30, 2004 | 05:45 PM
thanx for your help
Old Mar 30, 2004 | 06:54 PM
Ant7701's Avatar
Sweet as Gold
Thanks!
Yo...I can't remember...what size guages do I use for this pod...I got mine yesturday. I think they are 2 1/16 but not sure. Also I plan on buying a coolant temp guage but not sure what other guage to buy. I have I/H/E/P/chip as my mods and want another semi-useful guage...any ideas on what to fill it with???
Old Mar 30, 2004 | 08:58 PM
Guage size is 2 1/16.
With your mods (assuming you are tuning your car on a dyno with an A/F meter), useful guages will be fuel pressure. There really arn't too many guages useful on an NA car!
Old Mar 31, 2004 | 07:47 AM
scalbert's Avatar
Except for maybe a transmission temperature gauge for those 5AT drivers. :o
