? for people with pulleys
is there any issues with having pulleys?
I've heard that if you have pulleys you cant have a bunch of stuff on otherwise the lights will dim or something. Such as having the air on full and turning up the stereo.
Thinking about getting the AEM Tru Power Pulleys.
Thanks in advance for the help guys
I don't think the AEM pulleys will have any negative effect on your electrical system...even if you turn on everything in the car. I've done that and no problems to date ever since the install last year.
And, I just installed my system consisting of:
-Alpine CDA-7893 deck
-Alpine CHA-1214 12 disc changer
-Alpine Type R mids and tweeters
-Alpine Type R 6x9's
-Rockford Fosgate HX2 punch 10" subs (in a sealed box)
-Rockford Fosgate 1000bd monoblock amp
-Rockford Fosgate 300x 4-channel amp
-EFX Capacitor
Been running this setup for the past week and a half and no problems. My interior lights dimmed slightly once(I had just started my car and cranked it up right away).
-EFX Capacitor
Shit yea u did it right
. As long as u have that CAP in there u should be fine. But damm still even with a 1000W amp I would imagine that u would also need an Optima Yellow.
But as for a syock system, naaaa don't worry. The most that u should be worried about is the fact that the UR pullies have no harmonic dampener, like the stock ones do.
Juker008
. As long as u have that CAP in there u should be fine. But damm still even with a 1000W amp I would imagine that u would also need an Optima Yellow.But as for a syock system, naaaa don't worry. The most that u should be worried about is the fact that the UR pullies have no harmonic dampener, like the stock ones do.
Juker008
thanks guys.
helps a lot....especially since I plan on pushing a lot of wattage with my new system.
I read somewhere that you might have to have something re-calibrated or torqued after the install of the new pulleys....
is this true?
is this true?
Originally posted by nvpscore
UR pullies get more than 2-3 hp, at least 10 hp, and it cuts down on your loss through the engine due to auto or manual.
Nick
Nick
-EFX Capacitor
-EFX Capacitor
Re: ? for people with pulleys
http://www.aempower.com/application/...pplication.htm
Just click on the concentric circles for the dyno. Even at $150, it's pretty expensive HP ($50/HP).
Unorthodox Racing pulleys give 13.5 HP:
http://www.unorthodoxracing.com/dyno...%20type_s.html
Which at $300, is better bang for the buck ($22/HP).
Of course, AEM doesn't remove the harmonic damper, and UR does. AEM claims that it can cause long term engine damage, UR doesn't.... You make you're own conclusions... (of course, if AEM didn't believe it, then they'd manufacture pulleys to pick up the extra 10 HP, right?)
Re: Re: ? for people with pulleys
Originally posted by ScubaCL-S
So is it possible to find the weight of the harmonic Damper on the crank pulley and intall it on the UR crank pulley?
Someone would need to "carve out" the rubber inside the factory pulley and it is not a trivial project (like gluing some "set"/"fixed" amount of rubber to a "new" pulley). (There are other issues too...)
Originally posted by 2001CL
so what long term effects does it have on our engine? does that mean dont bother with the ur pulleys or it wont do that much harm?
The extra vibration will stress fracture the crank. There'll be a big bang, and the 3.2 l packs up. Not cool....
:o
that crank pulley spins really fast... no harmonic dampner means trouble... try looking for other methods of squeezing out more hp... 55 shot of NOS (probably can run more like 75)? headers? intake? supercharger? there's other ways than basically running a risk with pulleys that have been know to have issues...
OK hypothetically speaking if there are stress fractures in the crank and inevitably the engine blows. Would the manufacture (Acura) warranty the engine. Or would they say that with no harmonic dampener it cause teh problem and that they would not warranty the blown engine?
Juker008
Juker008
Juker008
Juker008
But, if that happened, it would be freaking messy!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
