passenger window will not roll up completely
Old Apr 11, 2010 | 05:28 AM
poisx7's Avatar
I put in a auto roll up swithc when i addded a DEI alarm about 5 yrs ago and everythings worked great till now.
The driver side still works great.
The probelm is when u hit the window up switch once the window is suppose to roll up all the way till it closes unless u hit it again which is suppose to make it stop but what happens now is when I hit the switch it just comes up a lil about half an inch and then stops (so i have to do this about 10x to close the window all the way), however the down button brings the window down with no problem at all but lifting it back up is where it is, The driver side windows works perfectly.
I initially thought i need a reset so i took the battery off and just got a newer battery with higher CCA and everything worked again for 5 days but after that it stopped working again. so I went out and bought a new door module with the new motors, assembly and everything but i installed it myself, added the expensive honda silicone grease and tried to see if it made a diffrence.
same shiT, window still did not roll up one one touch then I put back the old one in and returned the one i bought. Long and behold the windows worked again for a day or two no problems so I am kinda of confused was to what the probelm is.
I tried to control it from the passenger side and the driver side buttons with the same results.
Is there a reset for the power windows on the 2nd gen ClS ?
Old Apr 11, 2010 | 12:32 PM
civicdrivr's Avatar
Its probably the DEI auto-roll up that is malfunctioning. Take it out and see if the windows operate properly. If not, its possibly the window switches on the door.
Old Apr 12, 2010 | 11:58 AM
poisx7's Avatar
i thought of doing that.
i really wondered if it was the window switch but when It acted the same either from the passenger side or drivers side switch I just assumed it was NOT the switch.
Now only if i can find the guy who installed my system.
I know he put a DEI module in for auto roll up becos I dont think our cars have a one touch up button from the factory.
Old Apr 12, 2010 | 12:09 PM
Nicks01CL-S's Avatar
"DD" Designated Drinker
window regulator making any noises?
Old Apr 12, 2010 | 01:14 PM
civicdrivr's Avatar
The driver side has one touch up and down, the passenger side does not.
Old Apr 12, 2010 | 02:29 PM
poisx7's Avatar
nope
no noise.
Old Apr 12, 2010 | 02:32 PM
poisx7's Avatar
UMM MAYBE THAT has to do with it.
given that it is the passenger's side thatz acting up....
justin7779
Dec 25, 2015 10:33 PM
JnC
Sep 16, 2015 03:29 PM
Sep 15, 2015 06:44 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
