Parts Req'd for Timing Belt & Water Pump Replacement
Old 12-17-2007, 10:12 PM
mrsteve's Avatar
If someone has a list of parts required for the timing belt/water pump replacement I'd love for you to share it. Part numbers would be very helpful.
Thanks guys.
Old 12-18-2007, 08:38 AM
GreenMonster's Avatar
Someone started a list here:
https://acurazine.com/forums/showthread.php?t=192621
Old 12-22-2007, 07:05 PM
Honda Tech
jrmoskal's Avatar
I would say the all you really need is the timing belt, the water pump and a new serp belt and p/s belt since you'll have those off anyways. check the oil filled tensioner for the t-belt if its even a little damp replace it, don't risk it collapsing. I had this happen on a lexus and it was bye bye valves.
Old 12-22-2007, 09:08 PM
o1s
o1s's Avatar
aren't you forgetting all new gaskets?
Old 12-23-2007, 11:27 AM
Honda Tech
jrmoskal's Avatar
you really dont need any gaskets, the water pump has a new gasket with it and on the 3.2 engine you don't remove the valve covers or anything else, just the timing covers.
Old 12-23-2007, 11:58 AM
mrsteve's Avatar
Thanks guys.
I need to supply the parts, but a friend (Acura tech) of a friend (another Acura tech) agreed to do the work for $175.
Old 12-23-2007, 07:51 PM
russianDude's Avatar
I wonder if I buy new timing belt, what is the shelf life for it? lets say I keep it in plastic bag at room temperature for couple of years, does it mean that its lifespan gets shorter by 2 years when i install it?
Old 12-24-2007, 10:06 AM
CleanCL's Avatar
14520-P8E-A01 Automatic Adjuster
4400-P8A-A02 BELT, TIMING (197YU26)
19200-P8A-A02 WATER PUMP
Accessory Belts (power steering + alternator)
i would replace the auto tensioner(s)(not sure on the 6speed if there is 1 or 2). i'm guessing that's what the guy listed as automatic adjuster.
oh yea, coolant.
Old 02-26-2008, 09:53 PM
mrsteve's Avatar
Bump.
Is that all I need?
Old 02-26-2008, 10:20 PM
mrsteve's Avatar
Well, this is what I bought.
Old 02-26-2008, 10:21 PM
mrsteve's Avatar
I can't believe I'm spending all this cash on a car I really would like to sell.
New brakes (rear rotors, 4 pads) go on tomorrow morning. Sigh...
Old 02-27-2008, 02:51 AM
SodaLuvr's Avatar
Who did your purchase the parts from?
Old 02-27-2008, 07:48 AM
CleanCL's Avatar
ahaha, i've said it before and i'll say it again, i love your avatars steve....
Old 02-27-2008, 08:18 AM
Acura Carland
Old 02-27-2008, 08:49 AM
CleanCL's Avatar
oemacuraparts.com is cheaper
Old 02-27-2008, 10:19 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
And ebay is even cheaper still.
Old 02-27-2008, 12:07 PM
CleanCL's Avatar
i dont think you can find those parts on ebay, maybe the pump
Old 02-27-2008, 01:12 PM
SodaLuvr's Avatar
http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW
Old 02-27-2008, 01:50 PM
CleanCL's Avatar
did you look at the parts included in that auction?
not to mention it doesn't include more than half the extra things he ordered like the belt tensioners, hoses, belts, and thermostat stuff.
Old 02-27-2008, 01:51 PM
SodaLuvr's Avatar
It has everything you need except the drive belts and tensioner. You could probably ask them to include that for an extra $100-$150.
Old 02-27-2008, 01:54 PM
CleanCL's Avatar
also i don't see a need for valve cover gasket, spark plug gaskets, and cam seal gaskets. he is just removing the belts, he won't touch the cam seal unless you pulls the cam out. and crank seal??
Old 02-27-2008, 02:01 PM
SodaLuvr's Avatar
A thorough 105k service should include a valve adjustment, thus valve cover gaskets will be needed.
Cam and Crank seals are a good idea to replace since there's very little labor added to the bill once everything is removed.
Old 02-27-2008, 02:10 PM
CleanCL's Avatar
true, but he said his buddy was going to install the parts for 175... i doubt that includes a valve adjustment, although it's not the hardest thing in the world, dealerships usually charge a few hundred up to 500 for a valve adjustment.
Old 02-27-2008, 02:14 PM
I'm including the parts listing from the ebay auction here so we have a record of it when the auction dies...
PARTS LIST IN THIS GENUINE HONDA KIT:
TIMING BELT / OEM PART # 14400-P8A-A02
CAM SEALS / OEM PART # 91213-P8A-A01 X 2
FRONT CRANK (MAIN) SEAL OEM PART # 91212-P8A-A01
WATER PUMP / OEM PART # 19200-P8A-A02 W/GASKET
VALVE COVER GASKET / OEM PART # 12341-P8A-A00 X 2
SPARK PLUG TUBE SEALS / OEM PART # 12342-RYE-004 X 6 (OLD# 12342-P2F-A01)
mada51589
05-03-2022 08:54 PM
csmeance
09-10-2018 09:15 AM
V12 Inspire
09-10-2015 04:46 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: Parts Req'd for Timing Belt & Water Pump Replacement
