Painting AEM CAI?
Painting AEM CAI?
Anybody out there paint their CAI a different color?
Would this affect the heat dissipation?
Would I need to use a high temperature paint or does the CAI stay cool enough for normal enamel?
Why would you do that?? Please tell me you don't want to paint it pink or something! :P
I would use high-temp paint just because it's under the hood. you can probably get away with regular paint since the tube stays fairly cool, but why risk it.
It's called cold air intake because it draws air from outside the engine compartment. Not because it magically stays cold. Run your engine for a while and see how warm the intake tube gets from radiant heat alone.
You want the densest air possible and if you heavily paint the intake you may negatively affect the heat dissipation properties of the aluminum tubing.
Originally posted by CO-CL-S
It's a CAI ("Cold Air Intake"), where's the heat? If it's not on the exhaust it should be fine.
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
