paddle shifting the type S
have been curious anyone try this mod ? using a steering wheel from one of the other acuras that have paddle shifter?
Regional Coordinator (Texas)
i have an 09 TSX paddle shifter steering wheel sitting in my garage that i wanted to use for the exact purpose as you want. I even have the clock spring with all the wiring....
When I get time(never), i'll try to put it on Cuong's CL. Let me know if ur interested in it.
Whats up with RDX owners?
The 7th gen Accords can run the 3rd gen TL wheels with the paddle shifters, so I dont see why it wouldnt be possible to do it in a CL.
Unregistered Member
You think that would interfere with the transmission shifting? If it's feasible, then I'll be all over this mod. I'm not to excited about the 2G steering wheel design, so this would be a great mod to try out.
Hmm, the ECU is able to handle the shift requests via sports shift mode. I'm not good with automotive wiring, but it might be simpler than it looks? Need an expert opinion.
^ Yea, Im thinking that it would be easy enough to essentially "piggy-back" the wires from the steering wheel into the tranny ecu where the gear selector would generally change gears in sport-shift mode.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Received 1,080 Likes
I would think the biggest issue would be the clockspring in the steering wheel. If you could swap a wheel (like nspec_ya4 described) it should be fairly simple.
It's been talked about with the RL wheel but I don't believe anyone has done it.
hell, paddle shift and awd, how bout that?...lol
i think this mod with the paddle shifters can be done, it just depends how easily and how much it will cost...
'Cooter
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
If you had the clock spring to go with it it would be simple (granted it fit) Wiring would be easy. Just tap into the shifters ss mode wiring. I was able to switch the Upshift and downshift years ago when i had a auto.
3.7L Nitrous Breathing CL
What would make the paddles worth wild would be getting them to shift in actually time in any rpm. Instead off half the time it's delayed.
The sport shift does not really engauge as quick as it should. like it still wants to shift by itself unless you have the rpms high. Down shifts are alot quicker any any rpm.
Only thing I like about the sport shift is I can hold 2nd.
rockyboy
09-19-2015 12:09 PM
09-14-2015 10:48 AM
