p2r with or witout inatke manifold gasket
Originally Posted by Luca1014
I installed both and I didn't have to cut anything. The comptech tubing compressed because of the rubber couplings. It was a tight fit but its do-able.
Why do we need a intake manifold thermal gasket ??
Acura TL-S 02-03, CL-S 01-03
- TB Power Package: 2 Throttle Body Thermal Gaskets and 1 TB Spacer - $120 shipped
- Power Package: 2 Throttle Body Thermal Gaskets and 1 TB Spacer and 1 Intake Manifold Thermal Gasket - $150 shipped
https://acurazine.com/forums/showthr...pacer+comptech
Originally Posted by poisx7
For those that have installed the p2r spacer with other aftermarket CAI other than the p2r intake, I would like to know what p2r package to buy and the advantages of one over the other.
For the install you will need to remove throttle body anyways, might as well take it a bit further and install the intake manifold gasket also. While your at at you can clean the manifold and all the gunk around your egr port. This by itself is a good thing to do, made my car run much better.
Just got my P2R IMG, TB Spacer, TB Gaskets, and intake from Excelerate. Any suggestions for what I should use to clean my TB and Intake manifold while I have everything apart?
Uses turn signals in my
Quarantuning
InFaMouSLink
10-27-2015 06:52 PM
