P2R Intake manifold Gasket, Use with OEM? Outlaw?
So are you supposed to use the OEM metal gasket with the P2R thermal one? Also, i want to get the outlaw spacer, will the spacer work with the Thermal gasket and the P2R plenums?
Set ups, does it go
P2R-Manifold
Metal gasket-P2R-Manifold?
Metal gasket-Outlaw-P2R-Manifold?
Set ups, does it go
P2R-Manifold
Whats up with RDX owners?
You can use the metal gasket as well if you want, but you'll need two, one for each side.
No im talking about intake manifold spacer. I have the P2R Spacer and thermal gaskets on the TB. I also have the plenums with a thermo gasket, but im getting my valves adjusted soon so i was thinking about getting the Outlaw intake manifold spacer. So if i got the intake manifold spacer would the correct sequence be
Metal gasket-Outlaw spacer-P2R thermal Gasket-Manifold?
Or do you leave the metal gasket out completely? Is there hood spacing issues with both installed?
lowrd on tein CS biatch
ur right silvaccord
u could get that. and then get 2 intake manifold gaskets from p2r thus creating ur own spacer with super thermal blocking capabilities.
and if for some reason it doesn't fit to ur likings u have plenty of options since it is 3 pieces.
I doubt u'd have clearance issue though unless u got p2r plenums like me
Outlaw spacers, then the P2R plenums on top of that.
Should be.....
Outlaw gasket, outlaw spacer, outlaw gasket, intake manifold with P2R Plenums.
No others gaskets needed.
If you try you'll run into the hood. Mine just barely clears with the spacers & plenum. Dents the hood lining.
Should be.....
lol honestly I cannot see u being able to fit all of those under the plenums without having to make some room somehow.
They stick far enough out of the car as it is with just a p2r thermal gasket (very noticeable difference compared to the oem plenums if u look from the side of the car)
but it'd be interesting to see what's the most that u can fit.
let us know how she goes..
Should be.....
Should be.....
It also looks like the kit only comes with one extra gasket to put on top of the intake manifold spacer, and you reuse the oem metal one for below the spacer?
OEM-Outlaw spacer-outlaw gasket-Manifold?
3.7L Nitrous Breathing CL
No mdx spacer.And you hitting like that .
Wow those plenums must big huge since your getting hitting on the left side.
I was only hitting in the center beam and the map sensor is cutting threw the pad with mdx spacer and 2 thremo's on the clp manifold.
Are the outlaw gaskets thicker than p2r's ?
cycdaniel
12-17-2019 10:58 AM
mrkingstonvi
02-22-2016 01:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
