Overheats at idle
Old Sep 5, 2013 | 04:33 PM
Scratcher09's Avatar
Overheats at idle
I've only had this car a few days (use to have a TL). When I'm at a long stop light, after a few minutes the temp quickly moves up to about 3/4. It just stays there as long as I'm idling. As soon as I start moving it quickly drops down to normal again. Any ideas? Is this harmful to the engine? Both fans are operating.
Old Sep 5, 2013 | 05:48 PM
Brandon Allen's Avatar
2003 Acura CL-S6
Change your thermostat! I had this same problem a few weeks ago. Also look at your antifreeze reservoir and make sure the cypher hose is connected to the lid. I went ahead and emptied my out and filled it with all fresh coolant.
Old Sep 5, 2013 | 11:49 PM
OperationDarkie's Avatar
Ultra Negro
check water pump as well it might be on its way out
Old Sep 6, 2013 | 07:24 AM
fuzzy02CLS's Avatar
May just be air in the system or a faulty radiator cap. Try the easy things 1st. Burp the coolant & top off, replace the cap & go from there. Google it. The procedure is basically the same for most cars.
Old Sep 6, 2013 | 07:49 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
Is this with your a/c on? My car does it sometimes when the a/c is on if it's really hot and i'm sitting still
Old Sep 6, 2013 | 02:09 PM
aznboi2424's Avatar
Probably due for a coolant change anyways. Might as well do that while you're at it.
My car used to do that until I figured that only 1 fan was kicking on instead of 2.
Old Sep 8, 2013 | 10:03 PM
Got a thermostat and cap and going to flush system tomorrow. Internal reservoir pipe is intact and both fans are functional. I'll update when done.
Old Sep 9, 2013 | 10:17 PM
I replaced the thermostat and cap and flushed the coolant. I also noticed that what appears to be a temperature sending unit in the thermostat housing is broken. The plastic part that holds the plug is broken off so the plug does not stay plugged. Does anyone know what this part is called or what it does?
Old Sep 10, 2013 | 08:09 AM
fuzzy02CLS's Avatar
Coolant temp sensor I think. You can buy them fairly cheap.
Old Sep 10, 2013 | 11:16 AM
Looks like the broken piece is the fan thermo switch. It is located on the thermostat housing. Sounds like it tells the fan when to cut on and off. Not to be confused with the temperature sending unit on top of the water pump.
Old Oct 1, 2013 | 10:04 PM
Stephen Jackson's Avatar
x2
are u low on coolant? i'd check for coolant leaks,
Old Oct 1, 2013 | 10:08 PM
my bad didnt read last post...i work at advanced we sell those for cheap, go to the website and buy it. google some coupons to save some money
Old Oct 12, 2013 | 03:40 PM
Still haven't solved problem. I replaced both the sensors/switches that are in the thermostat housing, the thermostat, rad cap, and flushed and burped the coolant system. I am still occasionally overheating and loosing coolant. I can't see any coolant leaking anywhere but when it overheats I can smell coolant (outside car). I recently drove from San Antonio to El Paso (8 hr) and back. I had to pull over every few hours and add a quart or two of coolant to avoid overheating. There is no water in oil. How can I tell if water pump is leaking or bad? What else can it be?
Old Oct 12, 2013 | 03:59 PM
Nitin's Avatar
But I just got here
Seems like it's your headgasket. Just be sure to check your coolant level quite often to prevent overheating.
Old Oct 12, 2013 | 06:54 PM
If it is head gasket how can I confirm that?
Old Oct 14, 2013 | 11:40 PM
Does anyone know how to tell if my head gasket is where I'm slowly losing coolant? Thank you.
Old Oct 15, 2013 | 01:05 PM
Nitin's Avatar
But I just got here
Most places should be able to test the head gasket and see if that really is the issue. But otherwise some symptoms could be oil in the coolant or coolant in the oil. Also a smell of coolant coming from the exhaust.
If you ever notice, when the car is cold, that your radiator is low on coolant but your reserve tank is quite full, that could be another giveaway on it being the head gasket.
Old Oct 16, 2013 | 12:08 PM
I don't have oil in coolant or vise versa, but other symptoms sound accurate.
Old Oct 16, 2013 | 12:29 PM
fsttyms1's Avatar
I would have a compression test preformed on the motor, and have the cooling system pressure tested. If you are overheating and having to add coolant like you are there is either a pretty good leak or a blown gasket. The fact your fan switch was broken leads me to believe that you may have started to overheat one time due to the fan not coming on and have a bad head gasket/warped head.
Old Oct 17, 2013 | 12:05 AM
How much do these tests typically cost?
Old Oct 17, 2013 | 06:06 PM
Tosh's Avatar
Eurotrash
You need to find a competent Honda specialist.
Sorry to say, but you should have brought this problem to the previous owner's attention back in September as soon as you discovered it. (That's why he got rid of it...?)
Old Oct 26, 2013 | 01:28 AM
It was the head gasket. I can't afford to do the head gaskets. I know it's not the best scenario but I decided to use Blue Devil Head Gasket Sealer. I found a lot of people who said if the leak is small and it is used exactly as directed it will work. Fortunately it worked. I've been driving for a week now and no leak. I will replace the head gasket eventually but this bought me some time.
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
Skirmich
Oct 1, 2015 12:59 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
