Outside Temperture Gauge Reading
Old Jan 23, 2003 | 12:37 PM
RacerXE24's Avatar
Type-S Owns All
I am not sure if this has been addressed before, and it is not life threatening. But my outside temp always reads about 5 degrees above the real temp. And it does not matter how long I have been in the vehicle or where I am at. Does anybody else experience this or is this just something with my CLS only? Also does anybody know where the sensor for this is located? Thanks
Old Jan 23, 2003 | 12:43 PM
fender4's Avatar
you can adjust this reading,, it's in the manuel
Old Jan 23, 2003 | 12:50 PM
VeeDubDude's Avatar
can you post the procedure for calibrating and/or resetting the temp gauge? the temp gauge in my 2003 Accord reads 3-4 degrees higher and a few times it has "stuck" on one reading for a couple days at a time. the dealer says there's a way to reset it, but it's not in the manual and they "can't remember where they saw the procedure".
i might be able to figure out how to do it by comparing it to your procedure.
tks.
Old Jan 23, 2003 | 01:01 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
just read it in the manual...
Old Jan 23, 2003 | 01:03 PM
Soichiro's Avatar
Honda fan extraordinaire
There is a =/- 3 degree adjustment. Per page 22-83 of the (2001) Helms Manual-
1. Turn the ignition switch on.
2.Push and hold the SELECT and RESET buttons for 10 seconds.While you continue to hold the buttons, the display will scroll through temperature settings from =3 degrees to -3 degrees.
3.When the desired correction value appears on the display,release the buttons,and the recalibrated outside air temperature will be displayed.
4. If the outside temperature display is off by more than 3 degrees of the desired value,turn the ignition switch OFF and repeat steps 1-3.
This should solve the problem!
Old Jan 23, 2003 | 01:07 PM
joeandcarol2's Avatar
CL 6 speeder
Just read the post. He owns an Accord not a CL. He does not have a CL manual!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
