Outlaw Engineering Thermoblock Spacers and humming
White Type-S
Has anyone else experienced a hum/resonance after installing the Outlaw Engineering Thermoblock spacers? I hear it all the time, and I'm just wondering if it's normal.
a hum? more specifics would help. could be the hum from your intake
if the sound only happened after the spacers install i would think that they were not properlly installed.
i didnt notice any difference whatsoever with my thermoblok spacers
White Type-S
No CELs and I haven't noticed any weird idle.
I start the car and I hear a hummmmmmmm, and I can tell it's coming from that Intake/TB/IM area. Should I take it back to the shop where it was installed?
Received 1,080 Likes
Yes they do hum. The issue is that the spacer may have a slightly smaller opening than the tb. I rounded off the outside edges with some emery paper and the noise went away.
It's basically the air running over the edge of the spacer. Nothing to worry about.
https://acurazine.com/forums/showthread.php?t=148990
White Type-S
I contacted the shop and I was told to bring it in to have it checked out.
On a different note, the maintenance light blinks/flashes 7 times when I start the car. Is this because of scheduled maintenance needed. I'm 2K+mi. away from 90K.
rockvilleTL
09-19-2015 04:44 PM
04, acura, cl, engineering, imtb, install, installing, intake, kit, outlaw, spacer, spacers, thermoblock, thermoblok, tl
