Only 220 on a whole tank!!! WTF?
2003 cl-s auto.....72k miles......I did all city driving on this full tank of gas without flooring it one time...I only got 220 miles to the tank till the gas light came on...thats only like 14-15 miles per gallon. what gives? Let me know guys...should atleast be around 20 per gallon i thought.
I have noticed a slight decrease in fuel mileage with the mixture of ethanol in fuel. I was getting an average of 25 in combination interstate, and city. Note, I live in Montgomery County, MD where traffic sucks ass. Now I average about 22 miles per gallon overall.
I have a 6 speed. I am a bit heavy on the gas pedal.
It could be something as simple as bad gas. Fill up and run another tank from a different gas station.
Kenpachi Teichou
I usually get around 18-19 mpg because I drive in an area where there is a light every half mile and you will catch at least half of the lights at all times. I miss the highway so much ....
My guess is that you didn't fill it up all the way last time you tanked up... that and maybe you've been in vtec too much lately... Fill it up, and see if it does it again... Then you can start complaining
I've got every gas stop I've ever made w/ my CLS in a log book, so I can accurately check on fuel economy... It's been about 22-23 mpg for the last 4 years (52K miles)... Making assumptions based on one tank of gas doesn't work... Some tanks I get less mileage then others, but overall it all averages out.
Don't they teach you guys Scientific Method in school anymore ?? http://en.wikipedia.org/wiki/Scientific_method
We need repeatable, observable, empirical evidence before we can make judgement...
Oh, maybe you just wanted some WAG's (wild ass guesses) ??
edit: I've noticed that alot of people don't even know how to calculate gas mileage correctly...
Uses turn signals in my
check the air filter.
almost all the time with my friends vehicle that turns out to be the culprit.
my friends mustang (v6-stick) was getting 8 to 9 mpg, we cleaned out the filter on the CAI put in by the previous owner, he is now getting 19 mpg with not too much effort.
The filter was pretty damn dirty for the record.
Opium den in
Not a doctor
1 Post
that's strange
do you think that gas stations easing into their winter-blend gas early due to the drop in temperature could be the culprit? it probably varies from station to station.
i just got 25.4mpg w/ 369 miles to the tank,
which seems abnormally high for me....
last tank I got 340 miles out of a tank on all city driving. over 24 mpg 2002 cl type s
SOLD: 03 SSM CLS Auto
Originally Posted by RYANGP
that's strange
Back to a MT!
I get about 22-24 with my mix of highway/city, but in Orlando rush hour highway=parking lot!! Pure highway cruising I get 28-31 depending how loaded down I am. I just put the Acura Top Engine cleaner in my car and it blew out lots of soot. Maybe you need a good internal cleaning! Other than that, check your air filter I guess.
I use to get about 17 when I did all city. I got about 23 for mixed driving and up to 32 for all highway.
As far as miles per tank I got 235 mostly city, about 310 mixed and 440 all highway.
I saw no difference in mileage and performance when I went from Premium gas to Plus.
Only CL in town!
running ur a/c cud have alittle 2 do with it. i no i wont b much of a difference. i no i usually c about a 2 mpg increase w/o the a/c on. im getting about 18-22 mpg. alot of city and sum highway. hopefully sumthing isnt wrong with ur car
I have a 01 CLS auto with 63000miles and i've been testing my MPG and i've been averaging 12 to 13.33 MPG.. thats city and highway miles. The car is horrible.. i just ordered NGK iridiums IX to see if it helps.. the only mod in the car is the AEM CAI.. with the stock intake.. same mileage. I get about 180-200 a tank.. anyone have any idea of what the problem is?.. if no one does i'll change everything from sensors to plugs..
Gees, thats horrible. 200 miles per tank...
You're not trying to set a land speed record from stop sign to stop sign, I have some buddies who drive like that and they get horrible gas mileage.
But for that bad of gas mileage,
1.) use a fuel infector cleaner like Lucas.
2.) Clean your air filter again.
3.) Spark plugs like you said.
4.) What viscocity oil are you using???
5.) Get a scan tool and see if your engine is tossing any codes..
yeah.. ur tellin me.. its definitely horrible.. this is with normal driving(not driving hard).. thats why i figure something is wrong with the car.. i put a fuel injector cleaner every couple thousand mile and i know the filter is not the problem. i'm using 5w-30 motor old and i just order the spark plugs. If that doesn't help.. maybe check the oxygen sensors. Where could i get a scan tool to check for codes?
Take it to Auto Zone I think.
Also, change your PCV Valve while you're at it. It only costs like 10 bucks from NAPA, most people forget about this, but this wouldn't be your gas culrpit, just help with routine maintenence.
I have not figured out how many miles per gallon I get, before the turbo kit I would get 320-325 to a tank.
Now that it is turbocharged on the first full tank I got 317 miles, this is running 12-1 on the FMU which equals 8.0-1 on air fuel(way too rich) and 6 pounds of boost on an automatic.
I've got 141K+ on my CL, and can still easily pull 32mpg when doing only freeway driving, or 22-25 mpg when doing combined (depending on how hard I am on the gas). In fact last month my wife and I made a trip to santa clara and I pulled around 29-31 mpg easily.
There are lots of things to look at:
o2 sensor,
Dirty air filter,
dirty fuel injectors,
dirty TB,
dirty IMRC,
how much unnecessary weight you have in your car, depending on their size, subwoofer boxes will kill your mpg for sure.
but the one thing that can beat all of that is your lead foot.
o2 sensor,
Dirty air filter,
dirty TB,
dirty IMRC,
Moderator Alumnus
Winter-blend gas is coming out guys. ...and the gas you get out there probably sucks too.
I average between 350-400 miles till the light comes on. Super long trips I get near 475 miles on about 15.5 gallons.
-Chevron with Techron only.
Originally Posted by rtatsutani
I get 220-240 all the time if I just do city driving b4 and after mods. If I do any highway driving it jumps up to 240+. Don't worry about it.
Moderator Alumnus
Originally Posted by bmehling
one of the reasons I got this car and sold my camaro was for better mpg. Im gonna worry about it
East Coast Boost.!
Originally Posted by rondog
I'm lucky if I can break 200 miles to a tank. Weird thing is, my pilot is the same way, alot of city driving and shitty north eastern gas.
It's not uncommon for me to get 15 mpg city, but I still average about 26 mog on the highway.
Never had a clean run
last road trip I had I filled up in St Joe MI and did not stop again for gas until I got into MN about 510 miles away......but I only drove 75mph
been keeping the receipts from fill up and seen off the 14 gallons that i fill up with i get 22mpg mixed driving...and i have a 6spd w/AEM CAI....from reading what every one is posting im driving the car the way it should be...thought i had a heavy foot.
