Oil Leak help
Oil Leak help
SO i noticed some spots under the CL the other day in my usual parking spot. I thought nothing of it cause my car shouldnt be leaking oil. So i drove out again for a quick drive and noticed another spot of oil so i investigate. Its reddish and im thinking its someones tranny fluid. Then i'm thinking that this is my assigned spot and no one should be parking there so i look under the car and its pretty messy down there by the oil filter. My first htought was the filters loose but i couldnt hand tighten it so its gotta be on tight. Then i think maybe its that crush washer where the oil drain is, but that bold and area is clean. i get under again and notice that the oil filter and the surrounding area is pretty dirty with the oil spraying and i'm also low about 3 quarts. Would there be a spot above the passenger side motor area that would spring an oil leak? Havent had a chance to take it to a shop or actually get under it yet so any advice for peace of mind is appreciated.
On a 6mt that's likely the rear mail seal leaking. There's a TSB on it. If you have warranty it should be covered. If not, the tranny needs to come out & at that point you should put a new clutch in as well.
Originally Posted by NSXNEXT
Get some oil in the engine quick. If you are truly 3 quarts low, that's bad news for your engine.
, then another
and then finally another
This is the same car that had the mysterious coolant leak (loose drain bolt) that drained all my coolant while i was driving. I thought i would of had a BHG like my previous Legend
Originally Posted by Allout
That wouldn't occur on the passenger side of the motor though.
That's a first.
What type of filter was it?
IBankMouse
Jun 13, 2020 12:53 PM
