Oil Filter Review
Oil Filter Review
Getting ready to change my oil soon and found this site about oil filters.
http://www.ntpog.org/reviews/filters/filters.
shtml
So I thought to share the info, if not already posted.
shtml
Ambidextrous Masturbator
www.ntpog.org/reviews/filters/filters.shtml
Link-ti-fried! (aka Post Whore)
By the way, here are the results (they don't say much):
Conclusions
Essentially you will have to decide for yourself. How often do you change filters? If you answer is 3k miles or less, some of the cheaper filters are likely more cost effective and probably safe to use (like the Fram or domestic Honda). If the answer is 5k miles or more (say you use synthetic oil), I'd suggest a high-quality filter that should last longer like the Mobil 1, STP/Bosch, or Japanese Honda filter.
If you race, flow is as important (if not more) than filtering. The filters shown here with higher total inlet areas, largest cartridge clearances and fewest pleats are probably better bets. I would still recommend staying away from filters that use cardboard, simply from the consistently higher pressures in racing. I'd be concerned about the longetivity of the filter (cardboard) under those conditions. Then again, if you race, a higher capacity replaceable-media filter might be a better bet altogether!
Sid Vicious
2001 CL Type S w/ NAV in Silver | Wheel Locks | Front Plate (Mounted in the Trunk) | Mobil 1 | Polarg M6 NEW! |
1992 Ford Ranger XLT in Silver | F-150 Springs | 3" Body Lift | K&N Filter | Flowmaster Exhaust
[This message has been edited by SidVicious (edited 05-01-2001).]
Conclusions
Sid Vicious
From what information was there the Japan filter is the best, but you can't get it. Next comes the group of Mobil 1, STP/Bosch. Where the Mobil 1 may be better due to something on the filter element. The price of the STP is $2.86 (the Mobil 1 three and a half times that). I'd say from the info presented the STP is a no brainer. My last filter was the Mobil 1, have to rethink that..
Eat Safe, Use Condiments
Red CL-S, non-Nav, 35% tint, M6 driving lights, M4 map and door lights
<font face="Verdana, Arial" size="2">Originally posted by empeters:
</font>
</font>
www.amsoil.com or fun reading
http://www.vtr.org/maintain/oil-overview.html
If you want the best it's not that expensive. I change every 6k miles. I know of a CL-S owner in Miami that had his amsoil analyzed at 12k miles, the lab data showed his oil beat new 30w halvoline that they use as a standard. syn oil and filters are the only way to go. :
I'm not arguing the Oil side (I use Mobile 1). All I'm saying is that from the information in the independent (not checking everything) review, I don't see any compelling reason to spend more than what the STP filter sells for. I'd like to see a laboratory test that would actually test flows and filtering ability, if someone is aware of one please point us to it. I'd also like to see the Honda Japan filter available here..
IBankMouse
06-13-2020 12:53 PM
rcs86
08-02-2016 06:52 PM
STL TL-S
09-23-2015 08:52 PM
