Oil Change
Old Sep 5, 2008 | 06:26 PM
CL-Slick's Avatar
Chillin' in my trailer
Exclamation Oil Change
I was going to change my own oil today, but ran into a few problems. I know some of you guys change your own oil. First off, where should I put the jack stands. I had them on the sub-frame and it gave me hardly any room to work. Second, the last people who changed the oil torqued the drain bolt on so tight I couldn't budge it. Any help would be great.
Old Sep 5, 2008 | 08:00 PM
Ralphie917's Avatar
I usually jack up under the front of the car (lifting both wheels off the ground) than put the stands under the front jacking points (theyre kind of hard to miss, but u can consult your manual)
As for the plug... a nice breaker bar should do the trick...
I usually cock my wheels to the left also (makes it easier to get to the filter)
Old Sep 5, 2008 | 08:36 PM
CL-Slick's Avatar
Thanks man. I'll get the breaker bar tomorrow.
Old Sep 5, 2008 | 09:06 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
I usually just jack the car up a couple inches from behind the passenger wheel (wheel still touching the ground) and turn the wheel all the way to the right. You can change the filter and drain the oil without having to actually get under the car... They're both within arms reach of the passenger side wheel.
Old Sep 5, 2008 | 09:10 PM
CL-Slick's Avatar
Cool, but where do you put the jack stand?
Old Sep 5, 2008 | 09:20 PM
Don't even need to get the car up high enough for a jack stand... If you look behind the passenger side wheel, theres a jack point about in line with where the mirror is. I just pump the jack a couple times cuz my car is lowered. Turn your wheels to the right and look in from in front of the passenger wheel, you'll see the filter... The drain plug isn't much further.
Old Sep 5, 2008 | 09:28 PM
CL-Slick's Avatar
I tried it today, but like I said the drain bolt was torqued on, so tomorrow after work I will finish the task. I just hope that the filter isn't as tight as the bolt. I'm going to bring out the breaker bar and hopefuly be finished in 10min.
Old Sep 5, 2008 | 10:14 PM
swoleCL's Avatar
¿baCon?
for the filter, they make filter wrenches... pretty handy tool to have in your garage
Old Sep 5, 2008 | 10:24 PM
civicdrivr's Avatar
I don't even need to jack my car up, but my car stock height. If the drain plug is so tight, put the wrench on it and hit it with a rubber hammer a few times. Breaks it lose right away.
Oh, and always use a new crush washer.
Old Sep 5, 2008 | 10:25 PM
CL-Slick's Avatar
I have the oil filter wrench already, and where can I get a cruch washer?
Old Sep 5, 2008 | 10:34 PM
civicdrivr's Avatar
Honda. Just ask for the drain plug washer. They'll most likely just give you handful for free.
russianDude's Avatar
really, how the hell do you get under it???? ramps might be the way to go
Old Sep 5, 2008 | 10:36 PM
civicdrivr's Avatar
No need to get under it. Cut the wheel all the way to the right. Loosen drain plug. Slide oil pan underneath. Remove drain plug. Remove filter. Let drain.
It also helps to have long arms and be 150lbs
Old Sep 5, 2008 | 10:52 PM
How do you unscrew drain plug, you get to it through the space you get by turning the wheel all the way to the right?
Old Sep 5, 2008 | 10:55 PM
civicdrivr's Avatar
Yea. With the wheel turned to the right, my shoulder and arm can go under the car somewhat. I can reach the drain plug with a ratchet. I can still get the torque wrench under there too.
I used to work at an oil change spot, so I am used to tight spaces (try getting the oil filter on an RSX while the exhaust header is piping hot).
Old Sep 5, 2008 | 10:59 PM
I am going to have to try it, i was thinking of getting ramps, but I am concerned about not getting all oil out under the angle, and also would freak out if car crashes on me.
Old Sep 6, 2008 | 12:39 PM
bigmark89's Avatar
I Blaze Up In
Im lucky i have an actual shop that i take my car to and do all the work on my own. never had to jack up my car, always had a hydraulic lift. Just remember to lube the new filter around the lip and fill the new filter half way with oil
Old Sep 6, 2008 | 12:48 PM
phipark's Avatar
Not Asian
I just put a jack stand up on the right side on the jacking points. Turn the wheel all the way to the right. You can get a package of crush washers from Autozone or the like. I think they're 14mm washers, but can't remember.
Old Sep 6, 2008 | 01:03 PM
CL-Slick's Avatar
Thanks for the info ono the crush washers and lubing the filter. I will go by AutoZone after work.
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
