OEM Fog Light Kit
Hes got an 03, so there needs to be wiring. Unless he had something else done recently that we dont know about (and how dare he hold out on us!!)
Im pretty sure he's talking about these though:
Well when I had my amp put in, they hooked up the remote line to a thick yellow wire near the driver's fuse box. The amp turned on whenever the key got switched to the "ON" position. I would probably tap it into there, no need for a relay or a switch.
Pics on my actual car in a few days when I get the chance.
Interesting. Still wont actually throw any useful light though.
And Im guessing those LEDs (the first setup) wasn't heatsinked and in a sealed enclosure? Either that or they had too much power going to them.
where can i buy an oem road lamp assembly? I plan on wiring them into my 03 & getting them retro fitted with the lexus IS300 projectors... does anyone have a DIY so they turn on with low beam and off with high beams? (not trying thread jacked)
http://oemacuraparts.com/
The actual lamp assembly is from the 01-02 model, 03 just had inserts. Retrofitting into the inserts would be better IMO
@civicdrivr @nersh7 --->> http://customlightz.com/?p=p_150&sNa...ight-retrofits
they fit into the same gen tl fogs, the place i want to do my work only retro into oem fogs...so inserts are out the question. But they remove the glass from it.
The TL fogs are larger then the CL road lamp assemblies.
If they manage to get them to fit, it most likely will be inboard where the road lamp is taller. The problem with that is there a nice piece of sheet metal directly behind it. Im interested to see it done though using the road lamps.
IIRC the TL fog lamps also use glass, while the CL roadlamps are all plastic.
I wouldn't mind having those on my car, they look ....tasteful are those being made?
I wonder if he would see me the one off stuff...I may have to ask.
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
been thinking about converting my highbeams to DRLs but im curious to see what Ron has up his sleeve. I like the idea of LEDs.
