OBX Vibration
Happens on mine. It's basically something you have to live with. I don't really even notice it much anymore. I just try and keep it out of the 2500-2800rpm range as much as often by usually stepping on or lifting off the gas
imma get mine installed next week, what shud i tell the people who install them?? just to use the stock gaskets. i have no clue wtf a gasket is. any other tricks to installing the headers??
Playing the ass here, why do ya'll need to fix this??
You pay for a $30k+ plus car, added headers and are willing to accept a problem??
Is OBX aware of this and correcting the design??
You should should not need to fix this, the manufacturer should...
Originally posted by Nashua_Night_Hawk
The problem is we need to locate the source of the noise. Then, we can fix it once for all.
There is no easy fix (other than removing them). You get that with aftermarket exhaust as well.
An old rodder trick for exhaust was wrapping a piece of bin wire (heavy gauge steel wire) around the pipe and tightening it. Location and amount of wire would change the tone and RPM (since you're changing the resonance frequency of the pipe).
.... or just live with it....
Header-wrap might work... but I don't trust OBX material quality and you might end up creating more damage in the long-run!
It's not going to fix the problem... just muffle a bit of the vibration.
I doubt the manifold gasket is going to fix this!
I really don't thick it is a gasket issue. If the gasket is vibrating, than it is also leaking. I love the noise and the $900 still in my pocket, compared to the Comptechs. But, if it was simple to get rid off, i would!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
