OBX Vibration
Old Jan 3, 2003 | 11:57 PM
mretif's Avatar
OBX Vibration
At around 2.5k they have a vibration does anyone else have this, i tried the search but for some reason it did not work.
Old Jan 4, 2003 | 12:19 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
It is a resonance sound, mine happens at 2800 rpm only when the engine is under load.
Old Jan 4, 2003 | 01:17 AM
darrinb's Avatar
///M POWER
how does it sound??
Old Jan 4, 2003 | 01:25 AM
Happy CL-S Pilot
like lose bearing or something like lose heat shield vibrating
Old Jan 4, 2003 | 11:16 AM
mretif's Avatar
i went back around to tighten the screw because that is what i thought it was but they were all still tight
Old Jan 4, 2003 | 11:33 AM
cusdaddy's Avatar
Happens on mine. It's basically something you have to live with. I don't really even notice it much anymore. I just try and keep it out of the 2500-2800rpm range as much as often by usually stepping on or lifting off the gas
Old Jan 4, 2003 | 01:01 PM
CLS2001_97124's Avatar
Revving at 9K...
Damn that sucks that you have to do that.. I read some post in the past, and some people said that if you use the OBX gasket, you will have this problem, but if you swap them out for OEM Honda's you should be able to fix it. Good Luck.
Old Jan 4, 2003 | 01:03 PM
Happy CL-S Pilot
The problem is we need to locate the source of the noise. Then, we can fix it once for all.
Old Jan 4, 2003 | 04:55 PM
juice's Avatar
Someone figure out how to fix this. I can live with it, but I would love to get rid of it.
Old Jan 4, 2003 | 05:02 PM
mretif's Avatar
the obx gaskets are a loose fit but i was missing one of them so i did get a honda one and it is a tight fix but i more or less made it fit, i agree it could be the gasket.
Old Jan 4, 2003 | 11:22 PM
darrinb's Avatar
///M POWER
imma get mine installed next week, what shud i tell the people who install them?? just to use the stock gaskets. i have no clue wtf a gasket is. any other tricks to installing the headers??
Old Jan 4, 2003 | 11:52 PM
mretif's Avatar
you should not use used gaskets, they help stop leaks.
Old Jan 4, 2003 | 11:54 PM
mretif's Avatar
When you go get them installed drive it around 2.5k and see if you hear the noise, if you do ask the shop guys to fix it and ask them what they did
Old Jan 5, 2003 | 12:04 AM
scalbert's Avatar
Playing the ass here, why do ya'll need to fix this??
You pay for a $30k+ plus car, added headers and are willing to accept a problem??
Is OBX aware of this and correcting the design??
You should should not need to fix this, the manufacturer should...
Old Jan 5, 2003 | 01:01 AM
darrinb's Avatar
///M POWER
do the comptechs have resonace too???
Old Jan 5, 2003 | 04:02 AM
Chief F1 Fan's Avatar
Mine only does it occasionally, no rhyme or reason with respect to frequency, at about 2500. Sounds just like a loose heat shield.
Old Jan 5, 2003 | 04:05 AM
mattg's Avatar
mine don't
Old Jan 5, 2003 | 07:16 AM
devnull's Avatar
Working with Lumberg.
Absolutely right.
Old Jan 5, 2003 | 09:02 AM
scalbert's Avatar
Of the multiple sets I have installed, none have experienced this or any problem.
Old Jan 5, 2003 | 10:43 AM
Wires's Avatar
It's caused by the pipes vibrating (due to compositin and wall diameter). By changing materials and thicknesses you can move the resonance around. It's hust like a tuning fork.
There is no easy fix (other than removing them). You get that with aftermarket exhaust as well.
An old rodder trick for exhaust was wrapping a piece of bin wire (heavy gauge steel wire) around the pipe and tightening it. Location and amount of wire would change the tone and RPM (since you're changing the resonance frequency of the pipe).
.... or just live with it....
Old Jan 5, 2003 | 03:17 PM
allmotor_2000's Avatar
Header-wrap might work... but I don't trust OBX material quality and you might end up creating more damage in the long-run!
It's not going to fix the problem... just muffle a bit of the vibration.
I doubt the manifold gasket is going to fix this!
Old Jan 5, 2003 | 05:39 PM
6spdCL-S's Avatar
6 speedin'
Sounds like you guys should have spent the extra dough and bought the Comptechs. Mine have no problem here.
Old Jan 5, 2003 | 05:58 PM
mretif's Avatar
I tightened the heat shield bolds and the sound is almost gone, might want to try that
Old Jan 5, 2003 | 06:08 PM
juice's Avatar
I really don't thick it is a gasket issue. If the gasket is vibrating, than it is also leaking. I love the noise and the $900 still in my pocket, compared to the Comptechs. But, if it was simple to get rid off, i would!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
