NSX Brake Project complete
Old Jul 2, 2009 | 11:27 PM
  #81
OperationDarkie's Avatar
Ultra Negro
Originally Posted by StonedCL
The legend calipers have 2 pistons 38mm and 42mm
so to get the area of a circle is radias squared times pie.
so the smaller pistons total area is 1,133.54 mm
and the larger piston is 1,384.74 mm
so total mm area of both pistons are 2,518.28mm
The nsx caliper are 40mm and 34mm
smaller piston area is 907.46mm
larger pistons area is 1,256mm
Total mm area of NSX calipers are 2,163.46mm
The 1 cl piston is 45mm so total area of the piston is 1,589.625
So the master cylinder on our cars are pushing 1,589.625mm of piston area
the nsx is 573.835 MORE area that the master brake cylinder is pushing out
the legend is 928.655 MORE of total area ..
Thats where I got those numbers
nsx caliper is 1 40mm and 1 36mm piston
while the legend is 1 40mm and 1 38mm piston
not much of a difference there
Old Jul 2, 2009 | 11:48 PM
  #82
Ultra Negro
ok redid the math using the right size of the pistons
here is the formula http://books.google.com/books?id=sjd...esult&resnum=4
NSX caliper will exert 2389.54 lbs of force as opposed to 1661.6 from our standard caliper that is a 728 lb force difference which is spread out on more of the brake pad, which will increase the initial torque of the pad, that is almost 32 percent increase of braking force applied. Yes I was bored but i wanted facts to be shown.
30 percent more brake power, as well as more even brake pad wear will increase the life of rotors AND pads.
man was I bored.
and if you are really bored you can see how much force is actually required to lock the brakes up.
I didn't feel like doing that because I needed some fried chicken.
Old Jul 2, 2009 | 11:57 PM
  #83
Ultra Negro
Quick find for those who want to know as well
the rotora BBK is a 4 piston setup using 4 23mm pistons i did the math and guess what it came up as the same exact force as our stock CL pistons which is 1661.6 but that is spread out better so for best bang for the buck it would be better to buy NSX or legend calipers and use the rest of the money for pads and rotors.
Just for those who want to know
Oh forgot to take into consideration the slight larger rotor of the BBK, so its force would probably be around 2186 lbs + or - 100lbs
Old Jul 3, 2009 | 09:52 AM
  #84
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Thank you MR.Darko for the INfo..
Are u sure you MM are right on the legend and NSX caliper piston sizes, I know 2mm does not make that much of a difference but acuraoemparts.com gave me the piston sizes I posted where did u get your numbere?
Old Jul 3, 2009 | 05:35 PM
  #85
DC3328's Avatar
Your Garage
aluminum is lighter than cast iron right?
Old Jul 3, 2009 | 06:37 PM
  #86
Ultra Negro
I got mine from a friend that actually works on acuras, and the sizes he told me were for the 91-96 year calipers.
Old Jul 3, 2009 | 07:32 PM
  #87
Rajca's Avatar
wham bam thank you ma'am
aluminum is lighter
Old Jul 4, 2009 | 12:51 AM
  #88
adamlee05's Avatar
Thread Police Chief
They're not made of aluminum. Made of steel.
Old Jul 4, 2009 | 01:08 AM
  #89
DC3328's Avatar
Your Garage
yea im goin with the legends, nsx calipers were meant to stop a light weight super car not a boat like ours
Old Jul 4, 2009 | 01:43 AM
  #90
Ultra Negro
Nsx calipers and legend calipers are an upgrade. Period.
and they stop our boat just fine, ive messed around with them and have no issues what so ever and they are better than our stock single crappy pistons.
I just bought the NSX ones because you dont have to swap what side the caliper goes on just the get the bleeder screw on top, it was a straight bolt on with no hassle
To each his own.
Old Jul 4, 2009 | 02:07 AM
  #91
dave586270's Avatar
Chamorro
To each his own.
Wait you have to swap the Legend Calipers for the screw to be on the top? Weird. Well i guess i'll just flip the car over to bleed it then...
Old Jul 4, 2009 | 02:51 AM
  #92
adamlee05's Avatar
Thread Police Chief
Old Jul 4, 2009 | 10:18 AM
  #93
Rajca's Avatar
^do work son.lmao
Old Jul 14, 2009 | 08:10 PM
  #94
dave586270's Avatar
Chamorro
Originally Posted by adamlee05
haha, my thoughts exactly. Bleeding those bad boys today was a piece of cake!
Old Jul 14, 2009 | 08:15 PM
  #95
Rajca's Avatar
should be just like bleeding stock breaks. same thing with legend calipers. just need to swap them and your good to go
Old Jul 14, 2009 | 08:33 PM
  #96
dave586270's Avatar
Chamorro
Yep, thats what I did man. Worked like a charm! Pedal feels great, and brakes feel even better!
Old Jul 14, 2009 | 08:40 PM
  #97
StonedCL's Avatar
B A N N E D
Can I use the brackets that came w/the NSX brakes or DO i have to use the CL brakets to hold the calipers?
Old Jul 14, 2009 | 08:42 PM
  #98
Rajca's Avatar
use the stock brackets that are already on the car. the nsx/legend caliper brackets dont fit
Old Jul 14, 2009 | 08:48 PM
  #99
StonedCL's Avatar
B A N N E D
Sh()T I REALLY wanted to use these SEXY clean brackets that came with the NSX calipers!
  #100
dave586270's Avatar
Chamorro
Well i don't know about the NSX but the for sure with my Legend Calipers i was perfect with the stock CL brackets. bolted up like a charm!
Old Jul 14, 2009 | 09:46 PM
  #101
nf3d0149ab's Avatar
^ How much did you like them now?
Seriously better or not that much?
Old Jul 14, 2009 | 10:01 PM
  #102
dave586270's Avatar
Chamorro
Here is the install. Well worth the investment!
https://acurazine.com/forums/2g-cl-2001-2003-50/legend-caliper-conversion-735475/
Old Jul 14, 2009 | 10:57 PM
  #103
Ultra Negro
The difference for me was huge and Im on stock rotors with just some nice pads, but the initial bite is enough to throw you forward if you stand hard enough on the pedal.
But im scared to see how rajca will be once he gets his.
Old Jul 14, 2009 | 11:16 PM
  #104
dave586270's Avatar
Chamorro
Haha, feels good don't they? After i did some soft stops to warm 'em up i did nice stomp at like a 25-30 roll and i was surprised by how much i went forward knowing what i was about to do!
Old Jul 14, 2009 | 11:26 PM
  #105
nf3d0149ab's Avatar
I just wonder some times how I am able to stop...
If I didn't slam on those brakes...
Old Jul 14, 2009 | 11:36 PM
  #106
corsair's Avatar
Pilot Extraordinaire
Why change the brake calipers? Serious question. Soon I'm taking mine to the track to see how it performs. Just for fun, but is there a braking problem, or is it to look good?
Old Jul 14, 2009 | 11:52 PM
  #107
nf3d0149ab's Avatar
The problem is that our brakes for lack of a better word....suck!
For a car of this weight I personally don't feel they are strong enough.
Old Jul 15, 2009 | 12:07 AM
  #108
dave586270's Avatar
Chamorro
Exactly! Upgrades FTW!
Old Jul 15, 2009 | 09:24 AM
  #109
Ultra Negro
Actually the brake caliper itself isn't bad its just that the pad used in conjuction with it is too large for the single caliper which creates a hot spot in the pad which in turn creates more heat, increase brake fade as well as creating a big hot spot on the center of the rotor, therefore warping rotors.
the 2 piston caliper creates more surface area on the pad to dissapate heat, less heat means less chance for warped rotors and increased braking ability
Old Jul 15, 2009 | 05:05 PM
  #110
dave586270's Avatar
Chamorro
Well said
Old Jul 15, 2009 | 05:17 PM
  #111
StonedCL's Avatar
B A N N E D
Darko , Did u use the CL caliper holers or the ones that came with the NSX I really wanna use the ones that came w/da brakes from rockauto cuz mine r rusted.. Do u know if I swap the Whole setup if the screws and everything will line up?
Old Jul 15, 2009 | 05:46 PM
  #112
Rajca's Avatar
the nsx/legend brackets wont line up. use the tl/cl brakets with nsx/legend calipers. like i said above. thats it, unless u want to redrill new holes and tap them
Old Jul 15, 2009 | 06:23 PM
  #113
Ultra Negro
What he said
Old Jul 15, 2009 | 06:32 PM
  #114
dave586270's Avatar
Chamorro
What he said
Yep, just use the stock ones. My legends bolted right up!
Old Jul 19, 2009 | 06:34 AM
  #115
kuni808's Avatar
In 702, 808 in Dreams
Mr. Darko - the AC delco calipers have like a 5 day delay. did it take that long to reach you? Ive been thinking of doing this upgrade for years and i could not afford them cause they were up to like $150 to $200 each caliper. rock auto has them both sides for the price of one. thanks that is a huge help. how long did it take to reach you? thanks
Old Jul 19, 2009 | 12:14 PM
  #116
Ultra Negro
I got mine within 7-8 days, threw them on the day I got them took me 2 hours.
Old Jul 19, 2009 | 04:38 PM
  #117
StonedCL's Avatar
B A N N E D
I also ordered from rockauto one came in like 5 days and the other took 12 days
Old Jul 20, 2009 | 12:59 AM
  #118
kuni808's Avatar
cool! thanks guys!
StonedCL - how come one came in different times? is it shipped from a different location?
Old Jul 20, 2009 | 10:48 AM
  #119
StonedCL's Avatar
B A N N E D
cool! thanks guys!
Yeah one said its back ordered and shipping delayed 5 days, I belive it even said it on the website.. I was in no hurry.. I cant waqit to put them on now buy my car is getting its tranny rebuild .. I will get my car back wed and prob do the brakes next week. I have EBC green pads and the NSX calipers just gotta order some rotors!
Old Sep 10, 2009 | 07:49 PM
  #120
Silvaccordex01's Avatar
Was a little bored today so decided to bling up the emblems a bit
Enjoy!
Im suprised nobodys told you this before, but your squealers for the pads are on the wrong side. The pad with the squealers on it are supposed to go on the rear of the caliper (where you cant see it) and the one without is supposed to go on the front. The squealer is the metal bracket poking out of the pad
