noob audio question
Old Dec 27, 2011 | 10:14 PM
Jmoney6's Avatar
noob audio question
Before this gets moved to the audio section, i tried and got no answers;
Where is the sub in my car (03 cl-s 6speed)? Are the rear speakers considered subs or is there a seperate sub somewhere?
Old Dec 27, 2011 | 10:23 PM
distortedolskool's Avatar
no sub, just rear speakers. the amp is on the right side of the trunk.
Old Dec 27, 2011 | 10:25 PM
Jmoney6's Avatar
do the amp run all 4 speakers ( i have bose) or just the sub of the rear coaxial?
Old Dec 27, 2011 | 10:27 PM
all 4 are run through the amp and are just plain speakers. you have 2 ways in the fronts. the bose is just stock.
Old Dec 27, 2011 | 10:28 PM
Jmoney6's Avatar
ok, thanks
Old Dec 27, 2011 | 10:31 PM
Jmoney6's Avatar
I just got really confused by this thread: https://acurazine.com/forums/audio-video-electronics-navigation-22/keeping-factory-sub-when-adding-aftermarket-headunit-99-03-tl-326253/
Old Dec 27, 2011 | 10:42 PM
Originally Posted by Jmoney6
I just got really confused by this thread: https://acurazine.com/forums/showthread.php?t=326253
ya the TL had a sub while the CL got left out.
Old Dec 27, 2011 | 11:54 PM
ParaSurfer1979's Avatar
You didn't get that left out. The 6x9's in the CL almost has the bass of the 8in sub in the TL while the CL gets added clarity from the highs from the added tweeters in the A-pillars that the TL does not get.
Old Dec 28, 2011 | 12:21 AM
slvrdrgn123's Avatar
Anyone know how much power the amp in the CL puts out? Thanks.
Old Dec 28, 2011 | 01:28 AM
The Hondanews.com site doesn't give power but when I purchased my 03 CL-S 6speed new the power rating on the window read 160watts.
The 6x9's are indeed 2-way as i remembered and this site confirmed it...
PREMIUM MUSIC SYSTEM
The Acura/Bose® Music System is standard equipment on all CL models. Designed and built as an integral part of the car, this sound system is engineered to take advantage of the CL's unique acoustics. All six speakers have been strategically located and the bass response has been enhanced by utilizing co-axial speakers on the rear parcel tray.
The Acura/Bose® Music System includes a 6-disc, in-dash CD changer that allows six discs to be stored without a separate trunk-mounted unit or cartridges. Though it looks similar to a single disc, in-dash unit, the Acura/Bose" 6-disc in-dash changer stores up to 6 compact discs inside the dash-mounted unit.
The system will automatically shuffle the discs and allow for hours of constant or random music selections. The system also incorporates a cassette deck for increased audio flexibility. To allow the driver to remain focused on the road, radio stations, CD selections and volume can be conveniently operated from buttons on the steering wheel.
Old Jan 3, 2012 | 05:16 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
the factory system in these cars is pure garbage, you could go out and spend as little as possible on replacement speakers and it would still be better
Old Jan 3, 2012 | 07:47 PM
fuzzy02CLS's Avatar
add a basslink or other small powered sub & it's fine for most people.
Old Jan 4, 2012 | 05:28 AM
bigdaddyKA8's Avatar
x2
Old Jan 4, 2012 | 08:52 AM
harvthesecond's Avatar
Yea I just added a sub/amp in my trunk and now my Bose stereo is perfect. Not sure why some think the OE setup is junk.
Old Jan 5, 2012 | 10:15 PM
Jmoney6's Avatar
Is the bose amp in the cl the same as the tl? Any way i could run a small 8" sub for now and utilize the stock setup? Or do the tl have a seperate amp?
Old Jan 6, 2012 | 07:58 AM
fuzzy02CLS's Avatar
Amps are different. There's no reason to swap anything from a TL for marginally better bass response. If you want better sound go aftermarket & be done with it.
Old Jan 6, 2012 | 09:58 AM
exl124's Avatar
Surprisingly, the stock bose speakers are pretty good if you have the right after market head unit. I installed a Premier AVIC HU and it sounds great. Plenty of bass response from the 6x9. Mind you, it will never win a bass contest, so if you are looking for deep bass, go with a sub.
Not sure if anyone has tried the Basslink, but I had it in my S2000 and it was not boomy. It was more of a mid punch. So if you want deep tones, go with a good amp and seperate sub in a box.
Old Jan 6, 2012 | 10:19 AM
fuzzy02CLS's Avatar
I had 3. 1 in each CL I owned. Plus had one in a suburban. Was fine for me. A little muddy, but workable.
Old Jan 6, 2012 | 10:56 AM
aep4749's Avatar
I built a box that housed a 8 inch kicker square sub that fit behind the opening behind the rear arm rest. It sounded great, the bose sounds really good with a sub filling out the bottom.
Edit: I'll probably sell it soon since I sold the car.
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
datadr
Sep 12, 2015 09:12 PM
