noise when applying brakes coming to a stop
I hear some varying noise (low pitched), sounds like "uh-uh-uh-uh..." as I am applying brakes and car comes to a complete stop. It only happens when brakes are applied, and my brake pads are not worn, however my rotors might be getting warped (but not that bad, I had them warped much worse in the past and there was no noise). You think the noise might be coming from uneven disks? I never had the noise, pulsating brakes yes, but no noise. Wheel bearing? I figure bad wheel bearing should make noise without brakes applied.
dunno about you, but i would assume through the winter my pad material transferred unevenly. when i push the brake about 10% the car vibrates, more pressure, no vibrations. I am just gonna re-bed the pads again, which should fix it.
i would get your rotors and parking brake checked out/adjusted. i get that sound a little on my rear passenger and it goes away when i apply the parking brake while im moving.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
