Noise from front passenger side wheel
Old Jul 22, 2004 | 09:33 AM
Nofear6370's Avatar
Silver Bullet
I am hearing a clunking type noise when i go over bumps on the road. It is more noticeable when I am driving on local roads at low speeds. It sounds like the wheel has a lot of play. I had it checked out at the place that did my tokicos and comptech springs and they say everything looks good. Any ideas on what this noise could be ? Also if I take it to the dealer will they cover something like a stabilizer link or cv joint under warranty or would they blame that on the comptech springs? I am not sure if supension parts are covered under the 50k warranty.
Old Jul 22, 2004 | 10:13 AM
russianDude's Avatar
check your acura emblem, mine was little lose and was clanking.
Old Jul 23, 2004 | 02:04 AM
CleanCL's Avatar
Were your tokicos and springs installed recently?
A friend of mine in a mustang has the same problem your describing. Tried spacers, tried tightening, tried bump steer kit. Ended up the place that installed his strut overtightened the cylinder (the middle bolt in the center in the engine bay strut mount) and it spun the cylinder and broke the seal and let all the gas out. Guess what? Useless strut.
Dunno if that helped at all, good luck.
Old Jul 23, 2004 | 07:36 AM
Nofear6370's Avatar
Silver Bullet
How can I tell if it is a bad strut? I had the install done back in april and I have driven about 4k miles since and the noise just started a few weeks ago.
Old Jul 23, 2004 | 08:38 AM
Excelerate's Avatar
Former Sponsor
The noise you're describing is usually a sign of a blown strut. The way to tell is to take off your wheel and see if there is liquid/gas on your strut. Then you will know if it was blown.
Old Jul 23, 2004 | 12:37 PM
Nofear6370's Avatar
Silver Bullet
I am having it looked at on Monday. I do think the shock is probably blown. I have only had it for ~6k, not sure what would have caused it to malfunction. The same wheels bump stopper is completely torn too.
I know that Tokicos have a limited lifetime warranty but I am not sure how it works when I bought them online through some dealer on ebay.
Old Jul 24, 2004 | 01:11 PM
CleanCL's Avatar
a friend of mine ran into problems with tokico, and they were blown, it can happen if not installed properly, or even just from the factory
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
nanos
Nov 12, 2015 08:41 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
