No Start, Then Start
Old Jun 28, 2009 | 08:12 PM
clinoak's Avatar
Yesterday, it was hot here (about 90) and I drove my '01 CL about 10 minutes, shut it off for 2 hours and then when I went to start it, it just turned over repeatedly with no sound of actually starting. Battery and starter turning over strong, no gas smell. I tried at least 10 times and had pulled out my AAA card and was about to call when I decided 1 more try. It started immediately just like it always has for 9 years and has been starting fine since. It remined me of my older cars years ago that was subject to vapor lock. Maybe it did not recognize my key (would it still turn over if that was the case?) I was using the original key. Any ideas? I hate to take it in and have a repair shop rip me off.
Old Jun 28, 2009 | 08:51 PM
Rajca's Avatar
wham bam thank you ma'am
load test the battery and they alternator. sounds like a failing battery.
Old Jun 28, 2009 | 08:57 PM
neyeswhip's Avatar
tigerstyle
OP said turning over but he meant engine was cranking. Turning over=engine starting. Sounds strange but i wouldn't really worry about it unless it happens again.
Old Jun 28, 2009 | 09:05 PM
Rajca's Avatar
doenst hurt to get a free battery test.
Old Jun 29, 2009 | 02:43 AM
aznboi2424's Avatar
if it wouldnt recognize the key, then the green key symbol would flash when you try to start the car. but yes it would still turn over since the immobilizer only retards the fuel.
Old Jun 29, 2009 | 06:55 AM
Pseudomaniac's Avatar
Could be any number of things. It's cranking, so battery is probably fine. You can test load your alternator by disconnecting the battery while it's running. If it dies - your charging system needs to be checked out - if it doesn't, I'd be more suspicious of a fuel related issue.
How long since you did spark plugs?
Old Jun 29, 2009 | 11:05 AM
clinoak's Avatar
Thanks for all of your input- car is still starting immediately as it always has. Battery was tested at last oil change- I had asked my mechanic to just check the water in it and he tested it anyway. Spark plugs are original- should I be changing them now?- only have 69K. I was thinking it could be fuel or spark related since it was cranking strong with not a hint of turning over in 10+ attempts and then just started right up. Weird.
Old Jun 29, 2009 | 11:15 AM
DarkSithCL's Avatar
Be Strong AND Courageous!
Its the main relay.... 20 dollar DIY if you resolder the connections.... 60 to 70 bucks of you buy a new one at honda/acura... did mine last year and havent had a problem since... its from the "dry" solder points in the relay... you can actually see the bad ones if you really look... I just resoldered all of them to be sure.... its 104 here and mine is still starting fine... hollat at scottman... he just had the same problem too... now he's all good!
Later, Rick/ Sith
Old Jun 29, 2009 | 11:16 AM
DarkSithCL's Avatar
It will happen all summer off and on... trust me....
Old Jun 29, 2009 | 11:17 AM
Relay would certainly be another culprit. These were notorious for corroding away on the EF and EG civics and DC integras. Probably score one at the junkyard for next to nothing - but never know what you're getting either.
Old Jun 29, 2009 | 03:22 PM
Scottman111's Avatar
1919
Later, Rick/ Sith
Who me?
OP, everything you need to know is in this thread...just bumped it
https://acurazine.com/forums/2g-cl-problems-fixes-70/car-wont-f-%40king-start-daily-driver-488087/
Old Jun 30, 2009 | 10:49 AM
clinoak's Avatar
Thanks All for the input. I live close to SF Bay so it is rarely very hot here and the car is garaged at night and at work during the day. Perhaps I'll park it in the sun outside my house next hot sunny day so I won't get stranded if it acts up.
Old Jun 30, 2009 | 12:04 PM
DarkSithCL's Avatar
Originally Posted by Scottman111
Who me?
https://acurazine.com/forums/showthread.php?t=488087
LOL... See, I just mentioned you and you appear!
rockyboy
Aug 4, 2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
jordanboi
Sep 5, 2015 01:33 AM
