NITROUS!!! Wet vs Dry?
Meat stick
Originally Posted by allmotor_2000
Any type of nitrous is bad in the long run!
Dragging knees in
Dry will be easier to install, because you won't have to tap into the fuel line.
Dry will not pose a threat of detonation due to "pooling" of the fuel in the intake.
But when actually running nitrous, wet is safer because extra fuel and oxygen are coming in already mixed, maintaining safe air-fuel ratio. With dry, it would lean out the engine while nitrous is being fed.
It also depends on how big of a shot you want to run, too.
Originally Posted by juruki
I want to run like a 75 shot or less. I have Cold Air intake, will that reduce the chances of detonation because of pooling?
Meat stick
NOS utilizes a intense chemical reaction that needs to be controlled. FI is just air!
Im considering the ZEX 75 shot because its pretty affordable and many people here seem to be using it. My other choice is NX. What do u think about those? Also i had another question, do we really need the purge kit, the remote bottle opener and the bottle warmer? I dont think I can afford all of that....
Dragging knees in
Purge kit literally purges the nitrous lines so that you get a good delivery of nitrous.
Remote bottle opener has a servo that opens and closes the bottle by a switch. Since the tank is under pressure, it's better to leave it closed until you are about to use it. At the track, this isn't a problem because you know when you're gonna use it. But if you're going to race someone randomnly on the streets, then you probably won't have time to stop the car, get out, go to the trunk, open the bottle, and get in. By then, the other guy will be long gone. So with a remote bottle opener, you can open up the tank in a few seconds whenever you want.
Bottle warmer keeps the bottle warm to keep the pressure within range, useful if you live in cold areas. In California, you probably won't need it.
For occasional use, you won't really need any of those. But the remote bottle opener might come in handy if you spot someone on the streets and want to race.
something witty
I can get the transmission replaced at the dealer right? if i take out the nitrous system b4 i go?
You are literally fucking over the rest of us who absorb the cost to replace your tranny.
And BTW, posting about burning your tranny and replacing at a dealers cost isnt so smart to discuss on a public forum dedicated to Acura owners.
I have another question. Suppose you go to the track, do u shoot nitrous in first gear? second? Third? when you shoot it, do u press a button and let go right after or do u have to keep it pressed for however long you want the nitrous stop being sprayed into your intake?
You are going to want to buy a blowoff value & tube to prevent against rupture or bursting from pressure either in the lines or bottle. I use NX equipment but have a direct port setup,. Zex is a very good brand and a good value as well. If you go with a button, you will spray as long as you hold the button. If you want you can go with a setup like mine that has a RPM window which will only allow the spray to occurr with in a specified RPM range. I also use throttle position switch which activates the nitrous shot (instead of pushing a button) when the car is at WOT, it does this when a sensor under the gas pedal. This way you don't have to look down or take your hands off the wheel (altough some button systems work off the wheel for this reason).
Meat stick
Originally Posted by farberstyle
Yes you can, but you will also pay higher prices next time you want to buy an Acura.
If I gotta get my tranny replaced, i'm not going to feel bad abotu you...fuck you.
IIRC, Legends were built rock solid...did that mean that th CL/TL came out at a lower price than it would have if the Legend/Teg's had faulty tranny's? I don't think so. 3rd gen TL's are not much more expensive than the 2nd, even with the faulty 2nd gen slushbox. Acura's are priced high b/c they are luxury autos...you want cheaper?? buy a civic.
And I also think you give dealers WAY too much credit...no way will they go to the effort to first find out if you post on a place like this, second who you are on the place, and third file through your posts to find out that type of stuff......no way.
Originally Posted by JaredGMS
Well that's the dumbest thing I have ever read.
I think some people are just overreacting.
something witty
When someone says:
I just don't want to have to pay for someone else's error when I buy my next Acura
They are insinuating that if their transmission blows they will take their car to the dealer for replacement. I can't think of too many other modifications that are as volatile as nitrous.
this whole transmission fiasco is their problem, screw them.
Dragging knees in
That is the dumbest thing I've ever heard, especially considering the situation with the transmission in our cars. Whether people use nitrous or not, whether they have modifications or not, transmissions have been breaking down left and right. Yeah, it's possible that Acura/Honda will factor in the cost of all this into the pricing of their new models in the future. But even if they did, it wouldn't make a big difference in pricing. If you're worried about that, then don't buy an Acura in the future.
SidhuSaaB
05-30-2020 12:40 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
