New Intercooler Core
Old Jul 23, 2004 | 09:14 PM
scalbert's Avatar
I got the newly designed intercooler core in yesterday and I couldn't be happier with the results. Even though it is a little smaller it may turn out to be more efficient, still with no measurable pressure drop. And the welds on this things are incredible and on aluminum.
A little background first. The first unit, the one on my car, fits fine under the hood but hit the factory strut bar (which I still need to fix or make my own). Plus, it gives little hood clearance. I haven't hit it yet but I still worry especially considering this will go on 5AT vehicles which do not have the extra engine mounts that my 6MT has. So a new core design was needed.
This new one has the factory hood clearance. But the design of it is better than what I am using. It is better in two ways. The actual design is better for flow with the balanced entrance. And the core design is better for heat transfer. It is also still over-sized for the application allowing for up to about 600 CFM. Or more than we would flow with this blower.
For anyone who has read about forced induction knows who Corky Bell, this unit is coming from Bell Intercoolers. The gentleman I worked with on the design is Gerhard Schruf, his quick bio is below.
Gerhard Schruf has spent the vast majority of his engineering career working in the field of forced induction. Having developed turbocharged engines for marine, industrial, street and racing applications, with power outputs ranging from 50 hp to 40,000 HP. Gerhard was also instrumental in the initial development of the unique, pressure-wave-supercharger, the COMPREX. A highlight in his career was working with Gilles Villeneuve and the Ferrari Formula One team, providing forced induction expertise during the teams early ventures into the turbocharged era. As an author and co-author of several SAE-Publications his focus always was on performance, but in conjunction with fuel-economy and exhaust emissions for street applications.
I can't express how grateful I was to work with Gerhard. He obviously has the credentials but was also a pleasure to work with. He was patient and listened to my requests as we worked through the design.
Anyway, the images are below. The red caps are just protective during shipping. The three ports on the back are for vacuum fittings. The ports on the left and right of the main core are the water inlet/outlet. And of course the large cap to the rear right is the charge air inlet.
BTW, this thing should polish up nicely.
Old Jul 23, 2004 | 09:42 PM
CleanCL's Avatar
thats a WILD intercooler! i'm used to seeing just a really big rectangle, that is quite the design, you will have to let us know gains
Old Jul 23, 2004 | 11:42 PM
scalbert's Avatar
This is not the first and is a liquid/air unit. Not an air/air like most are use to seeing.
The gains were about 50 WHP with the additional boost it allowed to be run.
Old Jul 23, 2004 | 11:48 PM
sgmotoring's Avatar
Bleed Honda Blue
Is the price of this new intercooler the same as the old?
Old Jul 23, 2004 | 11:57 PM
allmotor_2000's Avatar
Polish it Steve!!!
Old Jul 23, 2004 | 11:59 PM
mattg's Avatar
someday, it will be mine.
scalbert's Avatar
Yep, this is what I based the price on.
Old Jul 24, 2004 | 12:00 AM
scalbert's Avatar
Originally Posted by allmotor_2000
Polish it Steve!!!
I'm still trying to get to mine. But I will provide instructions on how to do it your self for those few owners.
scalbert's Avatar
There is one small step before this though.
Old Jul 24, 2004 | 12:05 AM
scalbert's Avatar
BTW, as mentioned in another thread. I will probably end up with a 50 - 75 HP nitrous shot.
As Ramanan knows, I was thinking (and am still) converting to a turbo. However, this SC is more than enough power for everyday driving for me and I like the way it responds. But I would never shy away from having more. So a little juice may be in order.
Especially since the IC front plate can accommodate a fogger system nicely and that I can have the E-Manage control it.
Hrmm, blown motor in the future :lookingintocrystalball:
babyblue's Avatar
Sold but not Forgotten...
Steve once i get my blower with the High Boost Pulley i am definitely in the market for the intercooler.... will message ya once I am ready to purchase
mattg's Avatar
does it lay across the front of the motor?
after i go 12.5 on n2o it will be time to add boost.
Old Jul 24, 2004 | 12:09 AM
scalbert's Avatar
And replace the transaxle.
Old Jul 24, 2004 | 12:38 AM
mattg's Avatar
i've got 50k more miles of free replacements.
Old Jul 24, 2004 | 12:43 AM
Chemmech's Avatar
Wow!!! That is niiice! It turned out to be just like the sketches you put together. As it is, the IC looks polished already .
Old Jul 24, 2004 | 01:03 AM
mrsteve's Avatar
Wow, didn't realize you had a 2nd design in the works
Old Jul 24, 2004 | 01:04 AM
Chemmech's Avatar
How will this be mounted, orientated, on the manifold? Just a thought, with the IC and a turbo, would the lag be alot less than with a front mount IC?
Old Jul 24, 2004 | 01:17 AM
Mike's Avatar
Just so happens that I have a Nitrous systems dry kit for sale. 60 shot w/bottle warmer. Make you a good deal on it if you're interested.
Old Jul 24, 2004 | 06:21 AM
scalbert's Avatar
Exactly the same as the one on my car. Just shorter.
The boost response with a SC or turbo would be enhanced with this little of plumbing/ volume to fill.
Old Jul 24, 2004 | 06:22 AM
scalbert's Avatar
Naw, this will have the be a wet/fogger system. Thanks anyway though.
Old Jul 24, 2004 | 06:23 AM
scalbert's Avatar
It won't take much to get it shining.
Old Jul 24, 2004 | 09:19 AM
Smitty's Avatar
.... glad I am waiting....
That must of been a real milestone in your life to work with a MASTER like Schruf
Old Jul 24, 2004 | 10:15 AM
JaDia4's Avatar
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
Blown and sprayed? Wow! If you do TC what kit will you be using? Developing your own?
Old Jul 24, 2004 | 12:42 PM
scalbert's Avatar
Without a doubt.
But to top it all off, he was SOOO nice to work with.
Old Jul 24, 2004 | 12:46 PM
benzo555's Avatar
boo
WOW.. Incrdible!
Old Jul 24, 2004 | 12:47 PM
scalbert's Avatar
I really think I will stay with the blower. The current power is perfect for my daily drive. I just wanted more on a rare occasion which is where nitrous fits perfectly.
As for the tubo, if I had gone that route it would mostly be custom excluding the turbo choice. Why go through the effort of finding a turbo when allmotor and BlueCLS6 have already picked a winner.
Old Jul 27, 2004 | 07:40 AM
scalbert's Avatar
Just FYI, I should have new pictures of the complete assembly soo. The machine shop was further along than I had originally hoped. They just have the base plate to machine and then it is on to welding.
Old Jul 27, 2004 | 09:48 AM
av6ent's Avatar
Very COOL. So an order can be placed within next month and the turnaround time is still 8 weeks or longer?
Old Jul 27, 2004 | 09:56 AM
scalbert's Avatar
Yes, it will still be about that long. I can't stock these items as it wouldn't make sense so each is built to order. The lead time may be a little less but I would rather plan on it taking longer.
I still need to find a local AV6 to test fit the J30A1 base plate on it.
Old Jul 27, 2004 | 10:03 AM
av6ent's Avatar
Thats what I thought.
And Serge and Tony can use the J32A2 one since they have CLS heads and manifold.
Old Jul 27, 2004 | 10:07 AM
scalbert's Avatar
Yep...
Old Aug 15, 2004 | 09:35 AM
scalbert's Avatar
Just FYI, I'll be picking up the first two completed assemblies this Tuesday and will post pictures then.
Old Aug 15, 2004 | 01:43 PM
types1967's Avatar
yada yada yada lol
Old Aug 15, 2004 | 02:09 PM
scalbert's Avatar
Originally Posted by types1967
yada yada yada lol
You'll just be salivating when you see the new ones.
Old Aug 15, 2004 | 02:16 PM
STNG2NV's Avatar
Hey, I don't know to much about IC's, but I know I need one. Whats the difference between the Liquid-Air IC, and the Air-Air IC? Whats better, how do they both work?
I think the Air-Air, is just the IC, and you just connect to TB and the S/C discharge, but the liquid-air, there is something else that I am missing?? Fill me in.
Old Aug 15, 2004 | 02:18 PM
mrimage27's Avatar
steve i would love to get it, how much it going to cause me for everything?
Old Aug 15, 2004 | 02:19 PM
mrimage27's Avatar
steve how much for the setup?
Old Aug 15, 2004 | 02:58 PM
types1967's Avatar
steve your costing me money again damm car parts im going to end up living in the acura hotel!!! lol
Old Aug 15, 2004 | 03:13 PM
1killercls's Avatar
GEEZER
I want to see pics of the Intercooler POLISHED!!!
Old Aug 15, 2004 | 03:53 PM
scalbert's Avatar
An air/air unit cools the charge air with ambient air passing over the core. This is less complex but requres more plumbing in most cases. It is really only applicable to turbo systems due to the greater volume to fill.
A liquid/air system cools the charge air with water (or a coolant mixture) which is seperate from the engine's cooling system. Since this can fit under the hood thus having less volume to fill it is better suited for roots style blower applications. This requires a water flow system which has a pump and a heat exchanger for the coolant making it more complex.
For more details on both, here is a good link:
http://www.bellintercoolers.com/Pages/tech.asp
