Need some help:(((((
Guys i need a help
Today i finally got installed Ice Box .
On my way home i noticed that one of my headligths is not working but sligthly blinking
fog ligths are not working
and when i turn my emergency button on ..the other ligth is blinking too
. One of the headligths had some water inside before but they where working just fine
Did i do somenthing wrong when installing ICE box or the problem is bc of bad headligth? Any one please help
fantom, obviously the icebox butts right up to the (driver' side) headlight and wiring harness.
I have an '03 CLS, so I do not have foglights, but it sounds like you may have loosened a connector to the headlight or foglight during the install.
That is just my guess, but I would at least take the top of the icebox resonator off and take a look at the the wires and connectors. Good luck!
2003 CLS six speed
Icebox
2003 CLS six speed
Icebox
2003 CLS six speed
Icebox
2003 CLS six speed
Icebox
Sounds like you accidentaly knocked one of the harnesses lose. Just check to amke sure they're on tight. They should click when you snap them in place.
Originally Posted by RaviNJCLs
Did you fix the problem? When you installed the icebox, you were supposed to move some ground wires as well. Make sure they were reconnected securely.
if the one of the headligths is not working does the fogligths supose to be work?
Originally Posted by car_lost
if you removed the bumper, make sure you reconnected the fog lights.
that's happened to me before![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
What kind of problem did you had ? the only thing i cant understand is ...if the headlight not working ...why the fogligths are off? Are the connected some how ?
