Need install help of cabin filters
Old Feb 23, 2003 | 04:44 PM
davo-cls's Avatar
aka davo-tsx
I tried using the guide from Purolator, but it's not clear enough to follow. Can anyone give me a step by step or have pictures of which screws to take out, and how to get the lock tabs out of the glove box?
-Thanks.
Old Feb 23, 2003 | 06:10 PM
EricL's Avatar
Here it is...
Here is the excerpt from Jens on changing the "panel filter":
To access the interior air filters you will need a phillips screw driver a pocket flat blade screw driver and a sharp knife.Open the glove box and empty it of whatever you have been hiding in there.
there is a air piston on the right side that slows the opening speed it is attached to the door with a screw,remove the screw, pop of the air piston.
There are two stops on the inside the glove box, pop both out with the small flatbade.
The glovebox will now open downwards,there are two phillips screws holding the door to the dashboard structure,remove both screws the door can now be removed.
You will now see two phillips screws that appear to hold nothing inplace,remove these leave the metal clips in place.
There is a serrated panel visible it must be cut away from the dash board structure,save this panel as it is to be reused later.
There is now a vertical white plastic panel visible that can be snapped out of the way and removed.
The filters are the two vertical boxes now visible,remove the bottom one first by pulling it towards you then lower the upper one and remove it as well.
Exchange the filters noting that they have arrows on them for airflow,the boxes that contain the filters are marked as well.Install the filters in the boxes and reassemble the filters in to the airbox.Take the white panel and snap it back inplace.
Now take the previously cut out plastic panel and turn it so the two hooks engage the two slots in the dash structure,the two screws that did not do anything are now used to secure this panel in place.
Reassemble the glovebox in reverse fashion from disassembly.
This job should take you about twenty minutes or less.
Jens
Archives!
http://www.acura-cl.com/forums/showt...threadid=43416
Old Feb 23, 2003 | 06:49 PM
davo-cls's Avatar
aka davo-tsx
Thanks! I did a search earlier, but didn't come up with what I was looking for.
Feb 25, 2020 09:57 AM
bungln
Feb 20, 2019 08:47 PM
TxRzrBk
Sep 17, 2015 01:07 PM
ghuns
Sep 16, 2015 04:26 PM
Skirmich
Sep 15, 2015 06:41 PM
