Need help with Tein Basic Coilovers
Starving CLS Driver
I am interested in getting the Tein basic coilovers. I was wondering if this would be a smart purchase since my car has
235/40/18 tires with 18"x7.5" rims Offset 42. My main concern is rubbing. I know that i can adjust the height but i dont want to get the product if all i would be able to do is lower it by half a inch before it starts rubbing.
I think that some of the members on the forum with similar setup as mine had some rubbing issues when they lowered their vehicle. Any insight on this will be greatly appreaciated. Thank you
save a little more and get the ss.
Starving CLS Driver
Does anybody know any other place where i can get these kits for a better deal then autocarparts. The basic kit is $715 shipped and the SS kit is $965 shipped. Right now i am leaning towards the basic kit since it is a $250 dollar difference. Thank you guys for all the help.
Starving CLS Driver
A friend of mine told me that the SS kit is electronic and the Basic kit is not therefore making the labor almost twice as more on the SS kit compared to the Basic kit. Is this true. Also how hard is it to adjust the lowering yourself on both of these kits. Is it something that an amature with instructions can do or does it need to be done by a professional at a shop. Thanks guys for all the help, you guys have been great, especially
brianlin87
redryder83 and
Pure Adrenaline
for all the references.
brianlin87
redryder83 and
Pure Adrenaline
Dragging knees in
Electronic?? ![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Uh, has your friend ever installed struts/springs? I'm guessing no.
The best I can guess is that your friend is under the false impression that the SS kit comes with the EDFC, which has to run the wires all over the car, to the control unit by the driver's seat (wherever you choose to install it). Now THAT would cost a lot more than just a simple SS or Basic installation. Without EDFC, SS and Basic should cost the same to install.
Adjusting the height is done by raising and lowering the perch (spring seat). The kit comes with the tool you can use to spin the perch up and down. I think you just have to take off the wheel and go at it.
Originally posted by brianlin87
ur friend is incorrect, although the Tein SS does have the option of EDFC, it does not fit the CLs. the standard ss/basic do not have any hardware electronic that is needed for the install
they will fit in the rear. you would have to cut your hood to make them fit up front.
Starving CLS Driver
Another question please. Does the damper kit on the tein ss do the same thing as other camber kits. Just wanted to know if these two things are the same or totally different. Otherwords would i have to buy camber kits later if i get the tein ss. Many thanks.
you have to buy camber kits as well.
did you look at the link i posted for the apexi coils?
MrHeeltoe
20
02-23-2023 01:54 PM
ITSJESTER
17
12-06-2018 02:29 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
