Need help on icebox install
Old Aug 31, 2008 | 07:45 PM
kshhuang's Avatar
WS4 RSS4
need a little help on the install ..so to anyone who installed a icebox ..the part it ask you to remove the stock coolant/breather hose assembly and to use the supplied hose's....if i remove the whole assembly an use the 2 hoses the icebox comes with...what do i do with the 2 pipes that dont have hose's
hose 1 that goes to
here ..what do i plug this pipe with.?
hose 2 going to
TB what pliug this pipe.?
Old Aug 31, 2008 | 08:29 PM
glockyvt's Avatar
Okay, let's see if I can explain this well without pictures.
You've got the pipes a little mislabeled.
Let's call what you have in your second pic S1- This is a coolant line.
S1 runs from the plug in that picture to the plug you're showing in the fourth pic. It runs alongside the other pipe (S2), starting where you've circled in pic 1, splits where you've circled in pic 3, and goes to the plug in pic 4.
To double check, both ends should dribble a little coolant when you take them off.
The larger hose (S2) comes from the valve cover, and runs to the intake, just before the TB. This vents the valve cover to the intake, recirculating air trapped by the cover.
Old Sep 1, 2008 | 09:48 AM
kshhuang's Avatar
WS4 RSS4
so i have to find another hose to connect those 2 together than.?
i thought the whole kit came with everything
or does the OEM hose reach actually
Old Sep 1, 2008 | 11:06 AM
ljmushock's Avatar
When I did mine on my six speed I was stumped at this part too... I cant remember exactly what I did, but I do remember at the end I had taken out one of the metal tubing parts.
Old Sep 1, 2008 | 11:33 AM
glockyvt's Avatar
There should be two hoses in the kit. 1 1/2" diameter hose, and another (I think) 1/4" one. The 1/2" one should reach from the valve cover (not the hose you've circled, the bigger one it runs into) and run into the intake just short of the TB (shown in pic 3, but again, not what you've circled; the one right below it). The 1/4" hose should go from the connection in pic 2, and however you want to run it, and run into the connector in pic 4
Basically, what the kit does is eliminate that section of piping where the two lines are welded running side-by side.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Nitin
Sep 30, 2015 08:22 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Leester01
Sep 11, 2015 06:35 PM
