need help finding the mux panel(security module)
Old Feb 17, 2008 | 07:22 AM
suzook's Avatar
i have a 2003 cl. i am looking for the mux panel(security module). i have read it is behind the glove box. i have looked but cant see it. does anyone know EXACTLY where it is? i am trying to add on a remote start system connected to the factory sytem, so i can use the original key fob. i need to find the wire that pulses when i hit the unlock on my keyfob. i know the problems with the remote start and factory alarm, that is why i will be using 3 pulses of the unlock button. this way the factory alarm is off, and the car will start with no problems. is there anyone out there who knows exactly where this module is? please help. thanks
Old Feb 18, 2008 | 05:48 AM
suzook's Avatar
wow thanks for all the help guys. nobody here has done an install on a 2003?
Old Feb 18, 2008 | 06:25 AM
fuzzy02CLS's Avatar
Weekends are slow......
Not sure what exactly you want,
Immobilizer
Receiver unit is on the right hand steering column
ECM/PCM is behind the radio
Multiplex Control System
Passenger side = Behind the glove attached to the back of the fuse box
Drivers side same location but on the drivers side
Door unit is built into the drivers power window master switch in the drivers door
Old Feb 18, 2008 | 07:16 AM
suzook's Avatar
i am looking for the wire that controls the keyless entry. i am guessing the security module. thanks for your reply
Old Feb 18, 2008 | 09:44 AM
suzook's Avatar
well i found what i was looking for. there is a 5 wire tap that comes off the glove box light. the pink wire is the neg pulse for unlock and the blue is neg pulse for lock. these are from the factory key fob only, not the doorlock switch or key. this might help someone out in the future.
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Sep 17, 2015 09:01 PM
sputik
Sep 7, 2015 01:40 PM
