need help fast with brakes
Old Nov 23, 2004 | 02:42 PM
RR32CLS's Avatar
"hey...wanna f^&k"
ok, so i removed the caliper, removed the rear brake pads, now the problem is that after i installed the new brake pads, there is not enough room to fit over the rotor, the caliper is basically in the locked/engaged position, i dont have enough slack/room to fit over the rotor.
how do disengaged the caliper, free up space in the middle between both pads?
please help fast, while the car is jacked up...
thanks
Old Nov 23, 2004 | 02:56 PM
JaredGMS's Avatar
Meat stick
thanks
Use a c-clamp, and compress the piston back into the caliper. Remember to remove your brake fluid cap PRIOR to trying this.
HTH
Old Nov 23, 2004 | 03:48 PM
RR32CLS's Avatar
"hey...wanna f^&k"
thanks, i just removed the blled valve on the caliper itself and pushed it back in.
is that ok.. do i need to do anything else.
i drove the car around and everything seems fine.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
