need help fast with brakes
"hey...wanna f^&k"
ok, so i removed the caliper, removed the rear brake pads, now the problem is that after i installed the new brake pads, there is not enough room to fit over the rotor, the caliper is basically in the locked/engaged position, i dont have enough slack/room to fit over the rotor.
how do disengaged the caliper, free up space in the middle between both pads?
please help fast, while the car is jacked up...
thanks
thanks
Meat stick
thanks
thanks
HTH
"hey...wanna f^&k"
thanks, i just removed the blled valve on the caliper itself and pushed it back in.
is that ok.. do i need to do anything else.
i drove the car around and everything seems fine.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
