Need Help fast with brake install
Old May 29, 2004 | 05:30 PM
trifest's Avatar
Just did my front brakes with Axxiss pads and slotted/cross-drilled brembo rotors. Drove around the block and got back, weird noise which i'm not sure is because i did something wrong or it needs to break in. from a dead stop it seems like the brake pad is making noise when i go slow and have the brake slightly depressed (real light) but goes away when I release the brake. Is this because the pads and rotors have to break in or am did i mess up. didn't make this noise before with my old warped oem rotors and pads.
any help would be good. i've never done this before on an acure. done it plenty of times on my old cobra. thanks for the help.
Old May 29, 2004 | 05:39 PM
CLpower's Avatar
teh Senior Instigator
sounds normal to me, if you slightly depress the brake and the car is lurching forward there is usually a noise
Old May 29, 2004 | 05:50 PM
trifest's Avatar
phew i was a bit worried. i am quite happy with the combo. took forever to get the caliper bolts off. got some nice skinned knuckles to show for it. about to do the rears.
anybody have tips on the rear pads? i've been trying to figure it out because i could never do them myself on my cobra.
thanks for the quick response.
Old May 30, 2004 | 10:50 AM
Dave's Avatar
The caliper bolts on my '01 cls were no fun! I had to use a two foot pry bar!
Spray the bolts with liquid wrench or something similar and let set for a few hours. Other than that the brakes are pretty straight forward.
03 Silver CLS Six Speed
Icebox
Old May 30, 2004 | 03:54 PM
trifest's Avatar
thanks for the advice , got them installed perfectly, everything is a-ok
Sep 14, 2015 10:10 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
asahrts
Sep 4, 2015 05:55 PM
