Need Help - Bumper Dent and getting behind it.
Old May 7, 2007 | 08:20 AM
furious1smitul's Avatar
Terigan...
Okay so had a little bit of a run-in with another bumper over the weekend. It isn't all that bad so I figure for now I just want to push the dent out, however, there is this plastic thing at the bottom of the bumper, anybody know how to get those plastic screws off so I get get my hand in there and knock the dent out?
Also, has anybody fully replaced the bumper cover? If so, how much did it cost you, because there are quite a few chips from driving on the freeway so often that I might just get a new one.
Here is a pic, seems like it was pushed down a little to from the headlight housing:
Old May 7, 2007 | 08:48 AM
OrngeAc3.2's Avatar
i had the same type of dent but a little bit lower on the bumper...dont know how close you are to the North Wales/blue bell area, but i had a guy there pop mine out for 40 bucks i think?
otherwise you should be able to pop those screws out with a flat-head screw driver...
Old May 7, 2007 | 09:16 AM
fuzzy02CLS's Avatar
They are just pop in clips. Flip them out with a small flat blade. But your not going to have enough room behind to do it anyway. That is too close to the centerline of the bumper. The front bumper cross beam is in the way. Your going to have to remove the entire front bumper & then push it out from behind. See the bumper removal FAQ. The pics will show you what I mean.
Old May 7, 2007 | 09:32 AM
Terigan...
I work in Horsham, do you have the guys number? I think for under $100 I'd rather get somebody to do it for me.
Terigan...
Thanks.
Old May 7, 2007 | 09:43 AM
OrngeAc3.2's Avatar
i work in north wales, ill run over there at lunch and talk to him for a minute...he's actually doin my grill/emblems sometime soon so i gotta run over there anyway
Old May 7, 2007 | 10:15 AM
CleanCL's Avatar
you can probably get at that by removing your fog light and shoving your arm in there, no?
Old May 7, 2007 | 11:00 AM
fuzzy02CLS's Avatar
Don't think so, here's the pic of what's behind the bumper cover. It actually goes well into the bumper cover I don't see any room to do it unless the bumper is off.
Old May 7, 2007 | 11:02 AM
SuperTrooper169's Avatar
In the Mid-South meow
I just removed my bumper cover this weekend. It's actually a lot simpler than you might think. I also had my bumper cover repaired (under the guys insurance that hit me) and it cost just under $500 to have it fixed and painted.
Old May 7, 2007 | 11:04 AM
fuzzy02CLS's Avatar
Edit...Actually after looking at the pic it seems it's more to the side then the front, so it may be easy to push out.
Old May 7, 2007 | 11:58 AM
OrngeAc3.2's Avatar
do you guys think he might have to heat it or anything like that? you know, to make it easier to push out? just a thought
Old May 7, 2007 | 12:07 PM
Terigan...
That's exactly what I did
Although it didn't push out all the way so there is still a slight dent.
Old May 7, 2007 | 12:12 PM
Terigan...
I was thinking of that because as I said, there is still part of it that didn't push out so it is slightly indented.
Old May 7, 2007 | 01:04 PM
OrngeAc3.2's Avatar
furious1smitul-->are all of the stress cracks/spiderweb cracks really noticeable?
Old May 7, 2007 | 01:12 PM
Terigan...
Half as noticible than the picture above.
Old May 8, 2007 | 07:18 PM
Terigan...
So that slight dent went away on its own this morning. I am guessing the heat caused it to expand back to normal.
niray9
Dec 8, 2015 07:34 PM
usual suspect
2G TSX Photograph Gallery
Dec 7, 2015 10:52 AM
mugen_kid
Nov 13, 2015 10:38 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
