need help anybody experiece this??
Old 06-18-2006 | 04:30 PM
poisx7's Avatar
Well , to be put corectly i know a couple of people have experienced what i am abt to say. I just changed my brake set up, used slotted frozen rotors and them 95 acura calipers Ls legend. the install was all good except for the fact that you had to swap the right caliper to the left side and vice versa. the only problem i am having know is that the damn thing is making that clicking sound like i broke a bearing however it didnt b4 the insatll so i know its the brakes thats messing up. i am in the process of braking them in but this damn nosise is driving me crazy (sounds like a clicking or draging a few small tin cans along the road) annoying PLS what can i do to eleviate such a problem. i also used napa ceramics eventhough the manual for frozen rotors recommends using metallic pads
Pls anybody what can i do to quiet the noise down , i already am using napa ceramics, any suggestn, pls help help help ..................
Old 06-19-2006 | 02:11 AM
poisx7's Avatar
ehh no help not even a comment
Old 06-19-2006 | 02:18 AM
implicit's Avatar
eh
is it always clicking or only durring braking?
Old 06-19-2006 | 02:28 AM
poisx7's Avatar
As long as the wheels are spinning..
Old 06-19-2006 | 03:10 AM
poisx7's Avatar
always
Old 06-19-2006 | 03:31 AM
DutchCLS's Avatar
01 CLS
maybe the pads are catching on one or more of the slots on the rotor?? that's my best guess without additional info. If all else fails try putting your stock rotors on and see what happens.
Old 06-19-2006 | 07:14 AM
poisx7's Avatar
what do i do in such a case
Old 06-19-2006 | 07:52 AM
RaviNJCLs's Avatar
When I had my NSX calipers installed there was a similar noise, and it was contineous. Not just when I was braking. It turned out that there was a spring plate on the top. It's part 18 below, and it just slides into place on the top end of the caliper....
The CL does not have one. Took that off, and the noise went away. The edge of the rotor was just catching it, and causing the noise. The CL front brake set up is below. No spring plate....
Old 06-19-2006 | 08:12 AM
rockd's Avatar
2001 Acura CL-S
I JUST started having this same problem a few days ago... the clicking is continuous, but it escalates when I'm on rough roads.
It sounds like metal clanging every time the wheel spins... gets faster at about 10-30 mph... then cuts off at about 35-40 mph. I've been using the same rotors/pads (rotora/akebono) for about 10K miles, and they've been fine so far... any suggestions??
BTW, it's only the front wheels (maybe even only the left front wheel), and I can sometimes feel the clanging in my foot...
Old 06-19-2006 | 08:29 AM
poisx7's Avatar
Thanks 4 such info i had give that a try however i am suprised u said the Cl does not have one as i actually saw one in there when they took the stock calipers off, and i know another one came with the 95 legend calipers
BUT WHAT THE HELL IS ITS FUNCTION OR WHAT DOES IT DO MAY BE I SHOULD JUST REMOVE IT (PART # 18)
just to be sure are u talking abt that alluminium like metal that snaps and springs in to place ????
Old 06-19-2006 | 08:49 AM
RaviNJCLs's Avatar
I just removed mine. No problem after that. I don't remember seeing one when I had the CL calipers off.
Old 06-19-2006 | 09:52 AM
typeR's Avatar
CL has one...i think it's part 14 in the picture...i question the left for right rotor swap? what was that about? whY?
Old 06-19-2006 | 10:13 AM
RaviNJCLs's Avatar
The CL has 2 like the part 14 on either side. The Legend and NSX have a third one that sits on the top.
As for the left to right swap, it has to do with the position of the bleeder screw. It seems they are are on opersite sides from the CL. I think this is just for the Legend though.
Old 06-19-2006 | 11:21 AM
Excelerate's Avatar
Former Sponsor
(sounds like a clicking or draging a few small tin cans along the road) annoying[/COLOR]
Did you check to see if the brake shield got pushed in and is rubbing against the rotor. Typically that noise is related to the brake dust shield rubbing against something as the wheel is turning.
Old 06-20-2006 | 02:38 PM
poisx7's Avatar
RaviNJCLs
Thanks for the comment u were rght on the money, took the fake asz spring like thingy out ant that solved the problems..........................Thanks again............
Old 06-20-2006 | 08:46 PM
rockd's Avatar
2001 Acura CL-S
Just FYI - my problem ended up being the front left stabilizer link ($30.01 at the dealership) and a worn lower ball joint ($43 for a L/R pair).
Old 04-01-2007 | 04:31 PM
poisx7's Avatar
Can u resurface a slotted and cross drilled rotor ??
Ok back again. I installed a pair of slotted cryo frozen power slot rotors and them 95 acura calipers Ls legend in the fronts and cross drilled power stops at the back. i also used napa ceramics Worked well for the time being. But now they are warped again after spending abt 500 dollars.
What do i do now, can u resurface a slotted and cross drilled rotor ???
i did not think u could.......
I would have just waited and got the .....bbk
Old 04-01-2007 | 05:05 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
I know some places do it. Would probably be best to call several places, like O'Reilly's or other part places, even brake shops.
Wish I found this thread when I was searching for the same problem with that top retaining clip on the Legend calipers. Oh well.
Old 04-01-2007 | 07:52 PM
ironsurfer129's Avatar
CL-Pride
Some quick questions for all of you who changed caliper. Did you guys get brand new legend or NSX caliper, or used one? What year of Caliper for Legend or NSX fit or provides best result?
Old 04-01-2007 | 08:24 PM
poisx7's Avatar
rebuilt. its cheaper. at autozone or napa
i used a 95 legend
Old 04-01-2007 | 10:27 PM
o1s's Avatar
o1s
i think up to 96 nsx calipers work too. i think they are like around $70 for reman nsx calipers from advance discount or autozone.
MicroBurstGreen
4G TL Problems & Fixes
12-26-2012 07:09 PM
AcuraNH
08-08-2012 09:59 PM
gmoney25
05-15-2010 04:05 PM
zkahlina
11-05-2009 10:29 AM
Quick Reply: need help anybody experiece this??
