need to buy a Test pipe for acura cl-s 03
I had to have my custom made. Wasn't too bad....think around $150....but it is an exact replacement with matching flanges and the o2 sensor in place just like the stock cat. Check with you local muffler shop and they should be able to hook you up. Mine just required cash (no record) and did the install also.
For example just unbolt your exhaust from the cat back. Theoretically it will flow better and gain hp. Which is NOT the case. Trust me i have did it for shits and giggles and won't ever do it again..it's loud as hell and gave me worse gas mileage and power.
well I put a little home made test pipe of my car and felt immediate gains over the stock cat. Then I did some work to the car which resulted in the car becoming day and night faster as well as installed a 300 CFI Magnaflow high flow cat so I dont know what it did. I do hower by next spring plan on have a new high flow cat made so i can dyno it againts the high flow cat to if it it makes a difference for me
1 Post
If it does throw a code for the second O2 sensor, you can always do the defouler trick that will get rid of the code.
I don't condone taking out the cat completely. its good for the environment. especially since we can't tune our cars completely.
mike from annapolis
05-07-2017 08:21 PM
IIDXholic
10-08-2015 07:53 AM
trinikidcl
09-04-2015 12:56 AM
