navi question
Old Jul 28, 2004 | 04:38 AM
SocaliCLS's Avatar
navi question
i have 01 acura cls and today i noticed my navi gone haywire.. i was driving 405 north freeway but navi system said i was on the side street.. is this natural? thanks for your help..
Old Jul 28, 2004 | 09:53 AM
Chaptorial's Avatar
Yes this type of thing will happen from time to time.
I was coming over the George Washington Bridge once and it showed me cruising in the East River. Also sometimes I'll be placed on a street running directly parallel to the one i'm on.
Usually in about 30 seconds or so it will correct itself after it gets updated coordinates form the satellites.
What version NAV disc are you running?
Old Jul 28, 2004 | 03:52 PM
SocaliCLS's Avatar
i m running 2.05, where can i get updated dvd navi disk
Old Jul 28, 2004 | 04:15 PM
EL_CLS's Avatar
Devil's Advocate Returns
Current version for CLS is 2.11c
Try the link below or go to your owner’s link @ www.acura.com
https://iweb.alpine-usa.com/pls/isap_ap1/ha.header?p_make=Acura
The NAVI will drift from time to time, and depending on heat, mood, and other conditions, it will seem to suffer brain lock on occasion. Mine seems most likely to get “messed-up” when it is really hot out and it has a planned route in it.
Old Jul 28, 2004 | 04:43 PM
SocaliCLS's Avatar
beside than the updated street, is there anything else that the new 2.11?
Old Jul 28, 2004 | 04:57 PM
Chaptorial's Avatar
Well different points of interest now show up on the screen as little red dots. Things like Schools, govt buildings etc.
Click on them and it brings up their address, what they are and telephone number.
The other big thing is the ability to plan trips using unverified routes.
And what is Unverified Roads?
Originally Posted by CL P Diddy
With 'unverified' on the database will just incorporate unverified roads en route to your destination. With it off it will not use them at all. I just leave mine on. If there is an 'unverified' road in the directions to your destination the navi ho will let you know and you'll see a yellow window reading what she is saying. It won't give you a warning everytime just in the beginning and before you use the 'unverified' road.
Old Jul 28, 2004 | 07:42 PM
SocaliCLS's Avatar
i just discovered that the new dvd disk cost 189, is there anywhere you can purchase the dvd rom for cheaper?
Old Jul 28, 2004 | 09:57 PM
EL_CLS's Avatar
I believe that Alpine is the only place to get the "real" upgrade. (But, I didn't do an exhaustive check of EBay.)
I know you didn't ask this, but the disk is also two-layer which is good for having more rooms for features, but makes copying difficult when the data is rendered “useless” with the "lossy" compression used by DVD ripping software for movies, etc. IOW, the PC-based DVD copy software – that works by use of “lossy compression” (SQUEeezing) is of little use for NAVI data and code.
On the bright side (or dark side) there are some dual-layer DVD writers that are either out or coming out soon for your PC.
And... that's all I'll say for now...
YMMV
Old Jul 28, 2004 | 11:56 PM
mattdaddyz's Avatar
M to da DZ
YMMV
There are indeed. I just bought one from newegg for 74 bucks with free fedex shipping. It's an NEC dual layer dvd burner. It looks damn good for the price. I'm going to try to make a copy of my 2.05 navi disc. If i can successfully, then I'd like to try the 2.11 disc.
Old Apr 7, 2005 | 03:32 PM
cmltx1's Avatar
You don't need a dual layer burner to backup version 2.05B. I just burned a copy on a single layer DVD burner b/c it is only about 4.3 MB in size.
Old Apr 7, 2005 | 05:35 PM
123456SPEED's Avatar
CLS 6MT Navi
That's interesting, does it work? Never heard that before.
cmltx, What are you driving, I'm in Austin too.
Old Apr 28, 2005 | 01:39 PM
dlp's Avatar
dlp
So if we are to burn the NAV disc, what type of disc does it need to be? DVD-R or DVD+R?
Thanks!
Old Apr 28, 2005 | 02:33 PM
aspar's Avatar
there is an option on the menu to reaquire your position when it is off... press that and then just put the cursor on the road you are really on, and it will readjust.
Old Apr 29, 2005 | 01:51 PM
type1cl's Avatar
ok my navi is doing ok but on my screen when i got lower or higher my ac let say i got to lower the ac from 3 to 2 sometimes it wont do it it will change somthing else like the direction of the ac flow. do not what it could be
Ol'Dave
Sep 5, 2020 02:56 PM
06TLMatt
Oct 2, 2015 08:14 PM
datadr
Sep 12, 2015 09:12 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
Gianni Formica
Sep 7, 2015 08:28 PM
