NA Exhuast set up
NA Exhuast set up
Im looking to put together a high flow Custom cat back for my 6 Speed. if I have to have a resonator it has to be a high flowing one, and I want the mufflers to be as stock and free flowing as possible. I will probally want to weld on some stock looking tips to them preferably tips that resemble the TLS ones. What do you guys recormend?
yea I know, I was just looking at your other thread and was going to PM you and ask you what kind of mufflers you have. Unfortunately I need piping bigger than stock right so your nice set up wont do.
4drs just wanna have fun!
Run a 2.5 high flow cat, 2.5" piping and have it split to 2.25" at most. Use HKS mufflers or some Magnaflow mufflers, and maybe an inline straight through muffler acting as a resonator, like an ordinary glasspack.
Get that j-pipe done though, I think its holding you back a bit, just check the piping size on the collector and tell me what you find.
Whats the highest flowing not loud and crazy stock looking muffer that I can buy and attach my own tips?
140,000 miles young
As for the muffs, you can weld your stock tips to any muff but myself and many others have had good luck with Magnaflow. They are straight-through design and sound rich and not ricey at all. You can get tipless ones and add your own. If you want it too look super-stock then sand and paint the can flat black.
i measured last night and I was right. I would not go larger than 2.5 throughout if you do end up getting custom piping.
which one of this mufflers would perform the best and still keep a stock look?
http://www.hottexhaust.com/AluminizedOval.htm
http://www.hottexhaust.com/detail.asp?PRODUCT_ID=12216
140,000 miles young
I will probally go full 2.5 from the cat to the mufflers since im already running a 2.5 300 cfm cat so I will get this one, should be good for maximum flow. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Found out something weird today too - got under the car and looked around and it looks like some previous owner had the B-pipe replaced along the way. Whoever did it forgot to put the resonator back on so I have been running sans resonator from day 1 of owning this car and never knew it. I'm excited to pull my mid muff and add a high-flow res and see how itsounds. hopefully next week
That would work, but also consider you might be able to get away with 2.25" to the muffs and not lose any flow since you are splitting the single 2.5" pipe into two pipes. The sound will be different either way you do it - and from what people have done in the past I think 2.25 after the split sounds deeper. Ask around though.
Found out something weird today too - got under the car and looked around and it looks like some previous owner had the B-pipe replaced along the way. Whoever did it forgot to put the resonator back on so I have been running sans resonator from day 1 of owning this car and never knew it. I'm excited to pull my mid muff and add a high-flow res and see how itsounds. hopefully next week![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Biggie_B
02-26-2017 11:14 AM
