Mystery Mod PIC from SEMA
YOOOOOOOOOOOOOO!
Mystery Mod revealved (FOR REAL)
http://www.v6accord.com/forums/showt...?threadid=1931
Text:
It's a manifold intake mod.
Source Text:
ck Case Mystery Mod REVEALED!!!
Hello people, im here at SEMA with Gimmick. We just had a chance to check out what the "Mystery Mod" looks like. i dont think they even have a booth. We ran into the Rick Case guy(Doug), and he showed us what the thing looks like but, we still no idea what it Exactly does. He says it has something to do with resonance.
The thing actually mounts on the INtake Manifold, maybe even replaces it.
We also had a chance to see the supercharger. Beautiful!
We will post pics when we get back.
Text:
Source Text:
Re: Mystery Mod revealved (FOR REAL)
Text:
Source Text:
Text:
Source Text:
Originally posted by Mike
It can't replace the intake manifold
I thought you can make the throttle body bigger for my air to get pass...
LOL, well that could just mean it's a CAI then. You know, removes the resonator that quiets the intake (and restricts it like crazy), so therefore it creates more resonance, no?
Who cares.
Who cares.
1 Post
Maybe as posted by someone else (can't remember who, or in which thread) that it's a new top plate for the intake manifold. Additional space in the chamber would allow for some drastic changes in the "heimholtz resonance" effect. I'm no thermodynamic engineer (just a lowly EE ), but this makes sense.
Replacing the top plate would only take 5 minutes. This sounds like a great mod, especially for the bang it provides (dyno results.) And no ECU mods involved... equating to no real danger of voiding the warranty. This sounds great!
PICS AND MORE INFO PLEASE.
Jim
Jim
Oh...Behave!
Upper Intake Manifold Cover
From the ModMole: (Btw, WHO is he? - C'mon moderators, you can check it out!)
Uhhmnnn The Rick Case Mystery Mod is an upper intake manifold cover that increases the mass volume and resonance to create an increased intake charge.
Jim
Jim
"Since the Mystery Mod has been discovered by those who have already attended SEMA, it is no longer a mystery -- I'll confirm to all of you that could not attend SEMA that the above information is correct. That's the Mystery Mod.
I have to say that knowing what the mod was from day 1 (ok, maybe day 2) was kinda bugging me -- a lot of you came up with great guesses.
No electrical connectors, no moving parts, no warranty issues, LOW COST -- and it really can be installed in 5 minutes
Say it with me now: "We love you, Doug." "
Originally posted by juniorbean
Looks like MackDaddy hit it on the head... below is a post from RAdams, a mod from the TL board who I believe has been on here before.....
...it was me ...the someone else that mack was refering too...
Happy CL-S Pilot
Tim (Snook) has just confirmed that This is a new top plate for the intake manifold.
Link to Plenum + Helmholtz...
http://grapeaperacing.com/GrapeApeRa...ehelmholtz.htm
Who knows....
"Plenum Volume - There is not going to be a simple answer to the needed plenum volume for a given application or rpm range. The good thing about plenum volume is that there is a pretty wide range that it can be and still be effective, so general rules work well. The following guide lines are for engine operating in the 5000-6000 rpm rage. V8's with one large plenum feeding all 8 cylinders does not work all that well as far as the Helmholtz resonator goes, but if this is the case, plenum volume should be about 40-50% of total cylinder displacement. For a four cylinder 50-60% works well. For 3 cylinders (6 cylinder engine with two plenums), each plenum needs to be about 65-80% of the 3 cylinders it feeds. If a boost is desired in a higher rpm range, closer 7000-7500 rpm, the plenum will need to be 10-15% smaller. To get a boost in the 2500-3500 rpm range, it will need to need about 30% larger. The plenum size of a Helmholtz resonator may go against the typical plenum size rules, but the rules change when the resonator is being used. The whole Idea of a plenum is to allow the gases to slow down and gain density. The Helmholtz plenum makes a dense charge by use of pressure waves, in the same way tuned port intake runners work. This plenum sizing method does not apply to engines that to not use a tuned intake pipe. Many engine simply have the air cleaner assembly directly on the carb or throttle body having very little intake length. In those cases the Helmholtz resonator system does not work.
Who knows....
Blue Devil
[/i]
[/i]
Originally posted by WI CLTypeS
Okay I think I just had a few flashbacks to college Thermodynamics and HVAC classes. HEH thought I'd left that all behind! heheh
hehe i think i may be the only person that has a pic of it.
Too bad im not at home yet, im at a buddies house irght now and i have the pic of it on a cd.
To give you an idea, it is just polished curved cover with bolt holes for the J32.
check out the new thread/sticky over at www.accordv6.com
when i get home later tonight, i'll post the pic here/there/sho/and acura-tl
stay tuned
stay tuned
Mystery Mod PIC!
there you go guys, as promised
btw check out this thread
http://www.v6accord.com/forums/showt...3178#post16862
i added a TON of new pics from SEMA, lots of SC pics also.
1 Post
If Snook, or Syncivic reads this post, please see http://www.acura-cl.com/forums/showt...threadid=52305
TIA - Jim
TIA - Jim
OMG, you guys see the pics in http://www.v6accord.com/forums/showt...3178#post16862
of the Accord with the yellow bodykit that looks like a Mustang?
The tail on that car has the LEAST functional wing I've EVER seen. It's all thick and retarded looking. Looks more like it would IMPEDE airflow than aid it.
Jrock -
Shame on you! Your gonna post to this thread (about something else ,) and not comment!
Come on! Let's get the purchasing stage started!!!!!
Jrock -
