my CL started stalling when warmed up
Old 12-16-2006, 02:41 PM
09 TL SH-AWD
belcom's Avatar
Starts fine when cold... I would go for a 30 minute drive for example. Go to one place then another, and then try to start it... first of all it takes longer to start it and then it just sputters a little bit and dies. next time it dies right away and maybe 4-5 times in a row like this. Then I start and press throttle in a bit, the motor shakes but revving then after maybe 20-40 seconds holding the gas pedal in the same spot I can feel the engine kinda stops shaking and RPMs starts climbing smoothly and after that I let go off the gas RPMs drop and then it idles normally. Then I drive without problems. This happened maybe 5 times already in the last couple months so obviously it's not an every day occurence. But this is annoying as hell and I know that something is wrong. No check engine or CEL lights go on at any time so I can't hook up my scanner to see which code it throws.
I just have an Icebox intake with K&N cone and few months ago I installed brand new Denso Iridium spark plugs. also put in a sound system and installed additional 0 gauge grounding wires. I also had some fuel valve replaced which was throwing a code about vacuum in the fuel tank.
What could it be? a faulty coil misfiring? fuel supply? injectors clogged? something with electrical? a battery perphaps (still have the original but it gives steady 12.6v )? Alternator?
What's wrong with my car? Please help.
Old 12-16-2006, 10:23 PM
fuzzy02CLS's Avatar
I'd say a dirty IAC valve. Try cleaning it out, & the TB as well.
Old 12-17-2006, 11:39 AM
09 TL SH-AWD
belcom's Avatar
can someone post a diagram from the Hemls of the throttle body and IAC valve location ?
Old 12-18-2006, 07:52 AM
fuzzy02CLS's Avatar
It's out there in a post somewhere. The IAC is attached to the TB directly underneath it. And the TB is that thing at the engine side of the intake tube.
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
obert
12-14-2015 11:36 PM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
carz0159
09-20-2015 06:11 PM
ninersfgiantsfan
09-09-2015 01:14 PM
Quick Reply: my CL started stalling when warmed up
