Both my headlights went Out
Old Dec 17, 2006 | 06:24 PM
dre_CLS's Avatar
Exclamation Both my headlights went Out
Both my head lights went out on my 01 CL-s, I think my ballast are shot. The issue at hand is wether to get the dealer ballast, which probably is an arm and an leg or just replace with an after market kit. Need some advice A.S.A.P. Thanks
Old Dec 17, 2006 | 07:58 PM
dalostpinoy's Avatar
ABP CL-S 6 NAV
It would be usually for both hid ballast or bulbs to get shot at the same time. Have you checked the fuse?
If it is the ballast, check ebay or the black market here for used ones. stick to OEM.
Old Dec 17, 2006 | 10:13 PM
pits200's Avatar
He's right bro, the likely hood of both your ballasts going out at the same moment are almost impossible. A fuse is probably the most likely culprit, if I recall, both headlights run off the same fuse, but I am not to sure.
Also, be sure to check out the ground wires. You might need a volt meter to check this accurately.
Old Dec 17, 2006 | 10:52 PM
Corrosion's Avatar
White as night.
Slight correction: each headlight has its individual fuse.
Ballast is ~400 at the dealer
Old Dec 18, 2006 | 07:07 AM
pits200's Avatar
Ahh damn, I am giving false information now. Soon I am going to tell him that he needs to get turn signal fluid and that is why his blinker isn't lighting up.
Old Dec 18, 2006 | 09:16 AM
Lord Helmet's Avatar
I'm here in spirit...
I have heard of fuses causing this. Check the fuses first. If thats not it, prepare to buy ballasts. I'd look online before going to a dealer. Also, install them yourself. It's really easy.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
