My car have a bad idle problem guys! * Video*
Hi guys, i was going to work when i started my car it makes a strange idle problem.
take a look at the video:
http://www.youtube.com/watch?v=KN0EQN5dULo
NOTES:
- Same problem happened 2-3 times last winter when i start the car with cold engine. After 2-3 minutes, the problem dissapear.
- There is black Smoke comming out of the exhaust as you can see.
- Engine is shaking and idle goes Up and down.
- I cannot drive with the car, if i give too much gas, the engine will goes off
Thanks.
NOTES:
Thanks.
3.7L Nitrous Breathing CL
I would check the manifold first.
Mine was getting cloged up and I was starting to see the same issue.
Cleaned it out and no more idle issues at all.
my top cover was cloged pretty good and the 6 holes that go into the each manifold tube were about 25% the size they should have been due to the carbon/deposits.
Look at that.
Look at that.
I just watched the vid and mine was not that bad you could'nt hear mine threw the exhaust at all.You could notice it holdin the steering wheel with a little shake durring idle.
Check for leaks,rotted vac lines.
you need to get the idle stablized first before anything for sure
Whats up with RDX owners?
Id say IACV as well, but Im mostly concerned with the black smoke.
Do you have any CELs?
Black smoke from the fluctuating idle? That doesnt seem normal to me, unless its running rich.
lowrd on tein CS biatch
looks like a vac leak man that motor doesn't wanna stay going, check all hoses!!!
and then look into coil packs or w/e.
what is that rattling noise? it's quite severe. is that related to the motor problem? cause it sounds like the motor is being choked out.
Just unplug the iac and see if that changes the car characteristics. but i don't think it will. Sounds like the car is sucking up air when u were near the hood bro. Don't u hear it?
turn off ur a/c and see wtf is up.
if the motor is cold it will run with a vac leak but when it warms up it will choke itself out. so look into that and see if that is the problem.
but honestly it seems like a vac leak. loud engine bay and rough idle... looks to be the culprit
Zonian22
11-14-2015 01:20 PM
Mike Bertram
09-10-2015 09:27 AM
Zonian22
09-02-2015 08:19 AM
