My car always shocks me
Number 37
Why is it that I get shocked almost every time I get out of my car?!? It is really getting annoying and sometimes it hurts. Anyone else have this issue?
1 Post
i think it has soemthing to do with the tires. the car picks up static while driving from the friction between the tires and the ground. so when you get out, you ground yourself when you touch the ground, but then you touch a metal part on the car and the charge jumps from the car to you and through to the ground.
Find beauty in dissonance
Tires + dry AZ weather =
1 Post
maybe y ou should get one of those static antennas...you know, the ones that are supposed to dissipate static the car picks up into the air.
and if you like that one, try the tornado fuel saver too!
Number 37
Originally posted by Bluto
I agree with mrdeeno. What tires you rolling on?
http://www.startribune.com/stories/435/21169.html
http://www.alldata.com/techtips/1999/19980125b.html
The answer is: "You can avoid this shock by touching something metal on your car before you put your foot on the ground."
Re: My car always shocks me
You just have an electric personailty!!!
Number 37
Re: Re: My car always shocks me
There actually is a static strip that you can install. Haven't you ever seen a car with a block rubber strip hanging down to the ground, usually mounted in the back?
1 Post
HEY! there's an idea to save your rims!
No. Those are called curb feelers and are metallic.
The static strip is a thick black rubber piece, goes from the car to the ground. Just ask at any car part store.
Don't mess around. Do you know how many drivers actually dies from getting these shocks????
I love my CL-S
or just close it by pushing on the black plastic part around the glass.
sliding your slacks / shirt across the seat when getting out charges you up on a dry day. Wool on vinyl is a real killer.
touching the high capacitance car causes the spark to leap to the car just before you touch the car.
nothing to do with tires / driving, etc.
you can do it sitting in your driveway before driving off.
1 Post
i hear a recall coming. maybe even a class action lawsuit.
Learn to swim.
My theory: The charge either comes from the air passing over the surface of the car (as what happens in airplanes), or your movement insdide the car and the spark is the result of the difference in charge between your body and what the car knows as "ground".
EricL, where are you?
Originally posted by kensteele
Not entirely true: http://cartalk.cars.com/Columns/Arch...vember/11.html
Tom: Yeah. My shock comes when it actually starts!
Yeah... I think alot of Chrysler owners tfeel the same way!!!
www.drippinwet.com
The cause of car-door sparking is well known: contact-electrification between insulating surfaces, followed by separation of those surfaces. But what does this mean? Well, *YOU* are one surface, and the car seat is the other. When you sit on a plastic car seat in dry weather, the contact between your clothes and the seat's surface causes electrical charges of the material to transfer between the surfaces. This is our old friend "frictional" or "contact" charging. One surface ends up with more negative charges than positive, and has a negative charge-imbalance. The other surface has fewer negatives than positives, so it has a positive imbalance. This is nearly same thing as rubbing a balloon upon your hair: both surfaces become electrically charged.
However, nothing happens as long as you remain seated. Keep your butt in one place. As long as the surfaces remain near each other, no overall "electricity" appears and no sparks are possible. The oppositely-charged surfaces cancel out because they are still close together. But when you open the car door and step outside, you take just one polarity of charge along with you, while the car seat has the opposite polarity. At the same time, the car seat causes the whole car to become charged (by a process called "Faraday's Icepail Effect.") As you step out of the car, the voltage between your body and the car becomes huge, up to 10,000 or even 20,000 volts. Your shoes are probably insulating, so the charge has no opportunity to leak into the earth. You reach out to close the car door and ZAP!, the opposite polarities rejoin by leaping through the air while giving you a tiny, deep burn in the flesh of your finger!
How to prevent this? One possibility: change the surface materials. Identify and avoid the specific clothing which makes the problem worse. These materials are usually wool sweaters and pants, certain manmade fabrics, plastic raincoats, etc. Or, replace your cheap plastic car seatcovers with cloth (stains easily!) or leather (expensive dead animals.) Another method: mix up some anti-static solution and spray your car seats. This solution remains slightly damp for weeks, which halts the contact-charging process. The formula: a teaspoon of fabric softener mixed in one quart of water. This tends to work well at first, but after many days it wears off and needs a re-coating. Another sillier method: always drive barefooted, so the charge will leak away when you step outside the car. Not good in winter! Cover your car seats with a conductor such as aluminum foil, which screws up the contact-charging effect. Have a tailor make some custom clothing out of black conductive carbon cloth? Or you could eliminate the problem by eliminating your clothes. Skin is fairly conductive, so it doesn't create charge-separation when held against plastic. Driving while nude might cure the sparking problem (unless you are a very hairy person!) A less frivilous method: develop the habit of holding your car keys as you leave the car, then grip the keys firmly and touch the door handle with the tip of the key. The spark will still jump, but it will not be painful, since it blasts a little hole in the tip of the key instead of in your finger.
1 Post
Originally posted by aeon
How would your car build a charge from friction agaist the ground? How would you ground yourself steping out unless you were barefoot?
same principle.
'Cooter
i found a way to keep from getting charged...when u get out of the car, close the door using the black B-pillar...u won't get shocked, u'll close the door, and the charge will dissipate as u walk on the ground.
1 Post
Learn to swim.
and how does a balloon build charge buy rubbing it on your hair?
same principle.
same principle.
Think before you speak, or just shut up.
