my 3.5L journey begins...
Old 05-02-2006, 04:24 PM
  #121
typeR's Avatar
Originally Posted by CleanCL
thats almost identical to the setup i had in mind...
comptech downpipe to hi-flow cat to Y-Pipe for dual pipe split, into an X pipe and then to the mufflers.
i'm not entirely sure how effective it would be since no one has done it and i never plan on going FI. it would have to be something like 1.25" piping after the split, bc 1.5 or 2 i think would destroy any low end torque.
edit, with the hi-flo cat, y, and x pipe, no resonators are needed, it would def be loud, but i think it would sound great. but find me an X and Y pipe, with 1.25-1.5 inlets/outlets
just so you know that set up has some kinda valve that allows more flow at hi rpms and less flow at low...i think it could be easily adapted
Old 05-02-2006, 04:44 PM
  #122
typeR's Avatar
A hydroformed 2-into-1 collector pipe carries exhaust gases to a single 350 cell-per-inch secondary converter under the passenger cabin. To balance the engine's need for proper exhaust backpressure at low speed and free flow at high speed, the exhaust system incorporates a variable flow rate feature. An exhaust pressure-operated valve in the system has two operating modes. The low speed mode has a flow rate of 130 liters per second; when the engine reaches about 4000 rpm, the exhaust pressure rises enough to open the valve, which increases the flow to 150 liters per second.
BTW talked to acura247 and part number 12 which is the main character in doing this project is only 150$ i think it's where the exhaust pressure valve would be the only other place might be in the A pipe before the cat? i just dont see it being before the CAT? thoughts?
Old 05-02-2006, 10:11 PM
  #123
East Coast Boost.!
Titand19's Avatar
no traction is the problem
Old 05-02-2006, 10:26 PM
  #124
CleanCL's Avatar
part 12 in above picture looks like a plain resonator to me?? but who knows what's inside. sounds mechanically operated via pressure and no eletrical wiring is needed... i like this. this is intriguing, sounds like the perfect solution to maintaining low end backpressure and then opening up in high RPMs. i need to look into this further. i wish acura parts departments were actually knowledgeable about what the parts DO. i will be looking into this in the following week and report back results.
btw i still haven't gotten a chance to figure out the 6 speed throttle body, i'm contemplating just searching a junkyard.
Old 05-02-2006, 10:38 PM
  #125
typeR's Avatar
part 12 is not just the resonator it's pointing to it's the single inlet to dual out let
Old 05-02-2006, 10:49 PM
  #126
CleanCL's Avatar
part 12 isnt listed on acuraparts or acuracarland.. what's the deal?? honestly, i would adapt it to our single exhaust system, i still think it's too tight under there.
Old 05-02-2006, 11:02 PM
  #127
CleanCL's Avatar
OK OK, you got my brain on overdrive.
first some food for though:
http://www.racerwheel.com/a71-155a019.html
http://www.importscene.com.au/prod466.htm
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
this is starting to remind me of the IMRC valve. a secondary chamber opens releasing pressure necessary at high RPMs. this could show an increase torque in low RPMs. my idea, is part #12, if it is indeed 150, would be a steal. purchase that, i can mount it to the cat, and then run dual pipes from that piece. BUT WILL IT FIT?
Old 05-02-2006, 11:40 PM
  #128
typeR's Avatar
i know it's not listed thats why i called acuraparts247 snd they said they'd have to order it and that it would 150 shipped ...we need to look under an RL and we need to determin if this has the pressure valve in it?
Old 05-03-2006, 12:05 AM
  #129
CleanCL's Avatar
that has to be it, it's the only thing that makes sense.
want to go crazy? can you see the intake manifold bolting up?
Old 05-03-2006, 10:26 AM
  #130
typeR's Avatar
with 100% certainty
Old 05-03-2006, 05:08 PM
  #131
CleanCL's Avatar
the RL intake manifold appears to be way more effecient than the one on the CL, i would love to find one and PnP it. way too much new, anyone have any good junkyard sources?
Old 05-03-2006, 08:47 PM
  #132
ghost_masterCL's Avatar
LOL if you find on in a junk yard. that would have to suck for the person who's car that came from.
Old 05-03-2006, 09:45 PM
  #133
Blown is Best
Allout's Avatar
chances are anyone parting out a 2006 RL will sell the motor complete so getting an intake through a junkyard will be tough
Old 05-03-2006, 11:14 PM
  #134
CL SLeePeR's Avatar
They might have an RL laying around..
DIAMOND AUTO PARTS INC
FOND DU LAC, WI 54937
(920) 922-7731
parts@diamondap.com
Old 05-12-2006, 05:20 PM
  #135
CleanCL's Avatar
...transmission finally went. it may just be a sensor, but more than likely i toasted it. will find out sometime early next week.
Old 05-12-2006, 05:26 PM
  #136
typeR's Avatar
good time to get a good look at the under carriage of an RL
Old 05-15-2006, 01:11 PM
  #137
563hp daily
02AV6's Avatar
Looks good. And I'm curious how your Dr. Evil going to work out, my does as expected.
Old 05-18-2006, 08:34 AM
  #138
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
I had the same problem trying to source the TypeS IM for my 99TL. Finally found one from a board member. All the salvage yards I called said, sure we got one. Oh by the way, it's gonna come with an engine attached to it.
Old 05-21-2006, 09:54 PM
  #139
CleanCL's Avatar
minor update: crank being polished, intake manifolds port and polished, cylinder walls being honed, everything looking good. motor should actually be done by next week, but the tranny took a crap this week. motor/tranny get dropped thursday. i expect it to be done roughly 2 weeks from then.
Old 05-25-2006, 12:36 PM
  #140
ASM I.S. Design FTW.
brianlin87's Avatar
what's the turn around time for sending out your tranny to dr. evil? 2 weeks?
Old 05-25-2006, 03:08 PM
  #141
CleanCL's Avatar
normally 3 weeks, but i expedited shipping charges, so about 2 weeks from the time they pick it up from the shop. and my luck, monday is a holiday.
Old 05-25-2006, 04:32 PM
  #142
1999 CL3.0
dragon084's Avatar
dude whos doing the work?
whats up howve u been?
Old 05-25-2006, 05:12 PM
  #143
CleanCL's Avatar
well, i dont know how site policy works, but i'd like to give a lot of credit so far to RPM NYC (www.rpmnyc.com) for taking on this project. A small plug about them, they had a car at the New York International Auto Show that broke some kind of land speed record. They really know honda motors and I'm fully confident in them to complete this project. On a side note, they installed a regular j32 typeS into a 1st Gen CL w/ Standalone ECU Management. They said it sucked and it was a pain in the ass, but my motor should be very easy as long as the internals go good. If anyone wants some more info on them, just PM me and I'll tell you who to talk to.
I see you are in Florida now?!
Old 06-04-2006, 08:55 PM
  #144
CleanCL's Avatar
torque converter was being drained and sent out last week, i paid for overnight.
my motor was torn down last week, cylinders honed, block/head cleaned up.
things to be done in addition: jet-hot ct headers, hi-flow cat, full 2.5" exhaust w/ borlas. i need to ask them to weld my battery tray in place (custom mount). the upgraded motor mounts will go in as well.
i have so many parts at the shop, i will probably have a major sale when i get the car back, keep your eyes open.
Old 06-05-2006, 12:29 PM
  #145
CL SLeePeR's Avatar
On a side note, they installed a regular j32 typeS into a 1st Gen CL w/ Standalone ECU Management. They said it sucked and it was a pain in the ass...
That's a bold statement... What was their reasons? Just cuz it was a pain in the ass?
Old 06-05-2006, 02:19 PM
  #146
CleanCL's Avatar
they said it was hard to wire up everything, same thing Cocoa went through, gotta figure out what every single wire does for the ecu.
Old 06-05-2006, 06:52 PM
  #147
I'm a Vagiterian.
All Mine's Avatar
So another week or so?
Old 06-05-2006, 08:31 PM
  #148
CleanCL's Avatar
probly 2, maybe 3.
Old 06-09-2006, 01:04 PM
  #149
CleanCL's Avatar
tranny will be in sometime next week, motor will be set to go. then the exhaust gets fabricated. and the car will be done. wow. maybe 2 more weeks.
Old 06-09-2006, 01:10 PM
  #150
mrsteve's Avatar
What exactly are they doing to the transmission?
Old 06-29-2006, 09:00 AM
  #151
ChairmanMaoSaysRTFM
SatinSilverTypS's Avatar
hey mrsteve, i notice in one of your previous posts you advise against using dr. evil. any personal experience or the same skepticism we're all sharing now?
SSTS
Old 06-29-2006, 11:01 AM
  #152
chirik's Avatar
Dr. Evil is a great product as I heard. And doesn mrsteve ever owned one to be against it?
k bye
10-16-2015 03:26 PM
09-21-2015 08:44 AM
IlliniAcura
09-19-2015 09:31 PM
Quick Reply: my 3.5L journey begins...
