My 03 CLS6 Quest To Run 12.99 N/A & 12.50 With Nitrous
#561
All motor
See sig for details. Street tires. Anxiously awaiting your return to the strip with the new clutch!
#563
Alright will do. I'm going to be pist if it doesn't help lol. I'm going to place the 2nd one close to the location where the oem mid muffler sits.
#564
All motor
2.07. I missed 4th though, probably would've been a 13.4x.
#565
Damn not bad at all. It seems like your car is making some power then. Did you have a chance to weigh your car with you in it while you were there?
I'm sure if I put on a drag radial that will help on the et and mph n/a. Slicks have more rolling resistance, especially at low tire pressures. I might just try pumping up my slicks high when I try some n/a passes to compensate.
#566
All motor
Island Drag unfortunately doesn't have a scale. If I had to guess, with me in the car and 1/4 tank, I'd say ~3320lbs. I'm not really sure though as the 09 TL manifold is like 9lbs lighter than stock, but my exhaust may be heavier. Somewhere between 3300-3350 with me in it sounds about right. Only weight reduction is the spare tire.
#567
I'd love to run you. i don't have any track times myself nor do i have any dyno numbers on my j36. the new motor is untuned but your making me want to run nitrous in my car before I sell it. I was going to get a cobra like you haha but i found 6 speed single turbo conversion mkiv supra targa top with 60k miles on it for 20k. I'm hopping on that.
excuse the hideous exterior. this is my track setup and the whole car is going into paint next week.
#568
Just wanted to let you guys know I didn't forget about this thread. Things have evolved with the car and now I have even bigger and better goals. Also a lot more modding is being done to the car than I anticipated. It's a slow and steady process but I'll update this thread once the car is running again and I'll be able to hit the track. I have the itch and need to go back asap!!
#571
Yepp 11.50's or quicker hopefully!!! It should easily be obtainable.
#573
