My 03 CLS6 Quest To Run 12.99 N/A & 12.50 With Nitrous
#401
You guys are crazy for doing that lol! How much of a gain did the car make?
I think the cl does have a return system but I'm not 100% sure. I'm not tuned still running the stock ecu.
Don't feel bad my best was only a 13.9 N/A lol. I have some work to do and wanted to make more nitrous passes so I only made 3 passes N/A out of both the times I was at the track in the past two weeks. Thank you!
And here is what the car made on that dyno NA vs. Open Bottle Spray(SAE Corrected)
246whp/228wtq to 351whp/311wtq
#403
X2
#404
Here is the video from down there.
http://youtu.be/9FYWh9csyvI
#405
Nope. Did another pull after that and the NA numbers were consistent. Also we checked the plugs and they looked surprisingly good. The farther cylinders did show a little detonation(couple small flakes)
I little "Apple Cider" was a factor in this. My car also wasnt the only one that this dry shot method was done. The other was a HX35 Vitara SOHC that was having some issues with his direct port setup...
1foxbody (07-17-2012)
#407
im looking into doing a 50-75 wet shot for the accord. Button activated and with a window switch. Was looking at the Jegs one... http://www.jegs.com/i/JEGS-Performance-Products/555/40824/10002/-1`
Also to get some colder plugs.
#408
^ Do it.
It's crazy Fox...the car doesn't really sound any faster on the bottle lol. Meaning, the gears don't seem to 'sound' much shorter with the extra power. I would've thought 3rd/4th would've sounded much shorter considering the 12mph difference in traps.
Great times though! 12.5 is very impressive. Loving the trap speed too. Sounds like J's love nitrous....
#409
^ Do it.
Sonnick (07-17-2012)
#410
Anyone know how to remove proof watermark from these pictures?
http://www.flickr.com/photos/68917462@N06/7671316290/http://www.flickr.com/photos/68917462@N06/7671316290/ by http://www.flickr.com/people/68917462@N06/, on Flickr
http://www.flickr.com/photos/68917462@N06/7671316654/http://www.flickr.com/photos/68917462@N06/7671316654/ by http://www.flickr.com/people/68917462@N06/, on Flickr
http://www.flickr.com/photos/68917462@N06/7671316880/http://www.flickr.com/photos/68917462@N06/7671316880/ by http://www.flickr.com/people/68917462@N06/, on Flickr
http://www.flickr.com/photos/68917462@N06/7671317082/http://www.flickr.com/photos/68917462@N06/7671317082/ by http://www.flickr.com/people/68917462@N06/, on Flickr
http://www.flickr.com/photos/68917462@N06/7671317232/http://www.flickr.com/photos/68917462@N06/7671317232/ by http://www.flickr.com/people/68917462@N06/, on Flickr
http://www.flickr.com/photos/68917462@N06/7671317458/http://www.flickr.com/photos/68917462@N06/7671317458/ by http://www.flickr.com/people/68917462@N06/, on Flickr
http://www.flickr.com/photos/68917462@N06/7671316052/http://www.flickr.com/photos/68917462@N06/7671316052/ by http://www.flickr.com/people/68917462@N06/, on Flickr
1foxbody (07-30-2012)
#413
Once I have actual drag wheels with skinnys on the back that will be good for some unsprung weight removed. I can also remove the spare tire and jack. Not have a full nitrous bottle in the car if I'm running n/a. It's good to be very close I will need some perfect weather also.
I can guarantee a faster et on spray though. I will be able to raise the shot and actually hold the power.
Here's the list of people..
JBlueCLS6-$50
TheWeez-$20
INSPIRE 32V-$20
Richardparker-$5
Karanx7-$5
#415
The following 2 users liked this post by phee:
1foxbody (07-30-2012),
civicdrivr (07-30-2012)
#419
Yeah for now. My car isn't 100%. The clutch slips horribly. My n/a passes, which was only 3 total the car bogged on the launches. I found the sweet spot rpm wise for the launches after those passes. I will be going back soon..
#421
Dunno how I misread his text, it said:
"If he hits an 11.99 he earned his money. He's almost there in this heat."
I dont know why I had 12.5 on the brain. Thats entirely my fault.
#422
Good work on running a 12.5 on some juice and a slipping clutch, there's definitely more to be had there with a better clutch. Your na pass seems to be very weak for the power your making though. I would have expected you to be trapping at least 102-103s. Is your clutch slipping when your NA too?
#423
Also the clutch slips pretty bad even n/a also, since I launch at such a high rpm at the track. On the street it doesn't slip as bad because I can't launch the car that hard and usually I only run from a roll.
Here's my n/a pass listen to how bad it slips and how it bogged on the launch lol. There's definitely a lot more left in it!
http://youtu.be/ia8I7chL6HU?hd=1
#426
It's not the headers, its the full exhaust he has. Makes it sound like poopy. I wouldn't be able to deal with that on a daily basis. Have you thought about another resonator fox? I know you said you were considering it in the past. I'm going to be rocking a cutout on my car. Quiet & comfortable for daily driving, and ready for battle when you need to handle business
#427
1.8 on nitrous and 2.0 n/a
1foxbody (08-01-2012)
#429
A baffled resonator will hurt power. If you do a resonator, make sure it's straight through. The one Justin suggested is good.
Hopefully when you get that new clutch setup in your traps will increase for your N/A runs. I too, expected more in terms of trap speed.
#430
I already have the vibrant ultra quiet resonator on there http://vibrantperformance.com/catalo...products_id=47. It helped slightly but not enough for my liking. I knew it was going to be raspy when we built the exhaust but didn't think that bad lol. It's really only bad at lower rpms about 1.5k-4k rpm. I can sacrifice a little hp for a different tone with a baffled design or stick with what I have.
I don't understand how the magnaflow resonator that is the same design as my vibrant one will make much of a difference. I was thinking about just installing another vibrant to have two total or should I cut the vibrant one out and replace it with a magnaflow?
It sucks because the tone isn't the greatest but the positive part is I do have a very free flowing exhaust compared to other setups.
justnspace (08-01-2012)
#431
I'm sure my mph will increase with the new clutch setup. Another thing is it was very hot and humid so I'm sure that isn't helping either.
#433
That's probably what I will do eventually. At $110 a pop it gets expensive. I have a ridiculous amount of money in my exhaust so that's one of the reasons I haven't bought another one yet. You guys would cringe if you knew how much money I have tied up already on it lmao.
#434
#435
Here's some pictures I copied from my build thread so you can get a idea.
#437
Sorry I said cats thinking of the jeep. Yes I have a cat. Mine is around the same place and sounded like yours when I was at the track and sounded a lot better after throwing the vibrant on. I'd have to find some vids before and after but your exhaust is unique to that may be why.
#440
The Vibrant UQ is the only resonator you have? No wonder it's raspy as fawk lol that resonator is tiny. The Magnaflow will do a better job because it's larger. As long as you have enough volume of sound deadening, you can make a straight through exhaust quiet as well. Just add it right behind your current reso.
And trust me I know how much $$ can be invested in exhaust alone. I've changed through 4 different catback setups and 2 Jpipes so far.
