Mugen T-Stat
Old Nov 5, 2002 | 01:58 PM
scalbert's Avatar
Mugen T-Stat
I went ahead and ordered the Mugen thermostat, at the outrageous $69.00 price. I sure hope it is made of Titanium...
I did this for one reason, P0128; this is a DTC for the engine not warming up quick enough. It happened yesterday when my wife drove the car to the office (I had taken her BMW in for service, got a 530i auto for a loaner). It was about 50 degrees out and she started up and went allowing cool air to flow well before any heating had started. With the drilled stat in there the coolant flow increased revs was staying cooler than expected and the DTC was set.
So I ordered the Mugen T-Stat and will replace the stock unit this weekend. So for those about to do this, don't drill the stat unless you live in a constantly warm climate, just buy the gold plated unit...
Old Nov 5, 2002 | 02:10 PM
WiLd~CL~TYPS-@SS's Avatar
I love my CL-S
do you also have the Mugen radiator cap? would they fit our auto cl-s??
Old Nov 5, 2002 | 02:22 PM
scalbert's Avatar
Yes, I have the rad cap and the fan switch installed.
Old Nov 5, 2002 | 03:22 PM
Rescuer's Avatar
Evil Bob Knieval
i was going to be doing this in a few weeks
i'm picking up my B&M supercooler (70268) in a few hours
Old Nov 5, 2002 | 03:43 PM
I love my CL-S
can i have the part # and price??
thanks
Old Nov 5, 2002 | 03:55 PM
scalbert's Avatar
RADIATOR CAP 19045-XGER-0000 $29.00
THERMOSTAT 19301-XGER-0000 $69.00
FAN SWITCH 37760-XK5-00N0 $45.00
Old Nov 5, 2002 | 04:59 PM
randomwalk101's Avatar
if you have SC or turbo, that might help..but for a N/A car, sorry to say but it'd make VERY LITTLE difference..if any to be noticed by your car.
Old Nov 5, 2002 | 05:12 PM
scalbert's Avatar
It is not meant to gain something, it is meant to help not loose power. Plus, this is just an experiment to determine the validity of a report done by TOV. In some recent dyno testing done my TOV they dropped about 7hp and the same in torque when the ECT went from 180 F to just above 200 F.
You will never notice this amount even if it turns out to be true; this is about 3% which is imperceptible. Being able to not loose it is nice to know though. Who knows if that test done by TOV is accurate, they have no reason not to be and noted that most Hondas are this way. Some testing will tell though which will be done soon and there is no harm in that.
Old Nov 5, 2002 | 08:14 PM
Caddy©'s Avatar
Steve, did you ever get #'s on your Car after the P & P You did a while back ?
Old Nov 5, 2002 | 10:11 PM
scalbert's Avatar
Unfortunately no. So the variable gains will need to be deciphered. The plans is to go in the next couple of weeks.
Old Nov 6, 2002 | 03:30 AM
EricL's Avatar
Weird ... having all of those parts come off the Integra page!
http://www.kingmotorsports.com/produ...ra/engine.html
Did they have you look over your thermostat or did they finally decide that the 19301-XGER-0000 must be the "proper" one?
Were you getting a “bounce” with the holes drilled in the current thermostat (the coolant needle would move around depending on temp and load)?
Old Nov 6, 2002 | 08:49 AM
scalbert's Avatar
Actually I used the Civic page as a reference.
No, I'm just winging it assuming it will be right. They stated that there is only one T-Stat available and it fits all models so there is a pretty good chance it will fit.
No bounce, in fact it was pretty stable. It just took longer to warm up especially with revs increasing flow and airflow over the rad. But even if there is fluctuation you wouldn't see it on the stock gauge. The needle is in about the same location from 150 - 210 F. They might as well just have an idiot light as this gauge is meaningless as is with most stock gauges.
Old Nov 6, 2002 | 01:12 PM
EricL's Avatar
Bang-bang needles...
Hopefully you only need one at bat! When I called I got one story version and a second story version (I guess it depends on the phase of the moon when calling). The second was related to CLS via way of the Accord: "You have to pull the unit to see what it looks like ... two units can fit the car and depending on what the unit looks like ...." :P
I believe you and I’m surprised. The stock temp gauge in my Bimmer would at least move around in sync with a good aftermarket VDO gauge.
Acura CLS Headlines:
Precision instruments to be turned into an idiot lights
Engineers in charge of “Idiot Meter Projects” (IMP) have been turned loose on the gas gauge. After months of comments from Acura customers about variations in movement in their gas gauge from tank-to-tank, the IMP team will get to work on the 2004 gas gauge. The project will be called GIMP (Gas Idiot Meter Project).
F-C
Motorsports News
28
Sep 25, 2019 07:40 AM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
F-C
Motorsports News
14
Sep 28, 2015 12:54 PM
Iakonafuji
Sep 21, 2015 02:39 PM
