Mudguard install question
Moderator Alumnus
Okay, here's the deal. You unscrew the three screws, stick the mudguard on, put the screws back on. Couldn't be simpler, right?
Well, on my rear tires the hole there are only two screws, and there is a hole which looks like it should have a screw, but doesn't. And the hole isn't even completely there. At the moment the mudguard is just screwed in with the two screws but it moves a bit.
Should I just punch a hole there and use that clip thing?
900 club member
Yup, it worked for me and they are still on (but they sure hold a lot of water after I wash it - got to bend them to let the water out)
Powered By HONDA
i install my rear mug guards myself..it did not seem to have any problem..i do not even took my rear wheels off..and they are tight and will hold on for a life time
900 club member
DAMN! There are 2 little bitch sized drain holes in them! Mine were plugged with sand grains. Thanks for pointing out the drain holes Fast Daddy Car! Now I have 4 larger ones thanks to my trusty drill!
Skirmich
09-15-2015 06:41 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
