mt trany fluid?
Old Oct 19, 2009 | 01:37 PM
Elijah J's Avatar
mt trany fluid?
Ive used the honda fluid and the amsoil but am wanting to give gm a shot. Ive heard its the cremdelacrem but dont know which to buy. I stopped by the chevy dealership this am and they had two (semi synthetic syncmesh and an older type). I called acura to see what they had to say and was told not to use syncmesh but to use the honda fluid. Now, I know they are just wanting me to buy from them but am I correct in assuming that we use syncmesh in our 6speeds?
So please fill me in on exactly what I need to pick up from GM.
Thanks!
Old Oct 19, 2009 | 02:18 PM
fuzzy02CLS's Avatar
syncmesh
Old Oct 19, 2009 | 02:22 PM
Elijah J's Avatar
Originally Posted by fuzzy02CLS
syncmesh
Am I to assume it doesnt matter which gm syncmesh? the guy had two. The newer was semi synthetic and im not sure which the older one was but both were gm syncmesh.
Old Oct 19, 2009 | 03:17 PM
Elijah J's Avatar
i need to buy this before wed...
come on guys. I know tons have made the switch. I just need to know exactly what to get. Im getting the service done on wed.
Old Oct 19, 2009 | 04:48 PM
Elijah J's Avatar
the newer one semi synthetic and older is not synthetic at all. Which one are other people using?
Old Oct 19, 2009 | 04:58 PM
Six Shifter's Avatar
an adult perspective
221,108 miles on original tranny, only using Honda fluids. No issues. Why mess around?
Old Oct 19, 2009 | 05:38 PM
Rajca's Avatar
wham bam thank you ma'am
ppl feel that the gm stuff is way better than the honda stuff. 2nd gen cl and 3rd gen tl. not sure which one to get either
Old Oct 19, 2009 | 05:54 PM
fuzzy02CLS's Avatar
I would say the new stuff.
Old Oct 19, 2009 | 06:40 PM
Zippee's Avatar
I use the latest Honda stuff and it works fine. Why screw around?
Old Oct 19, 2009 | 06:49 PM
Rajca's Avatar
bc its proven and wont damage anything.
Old Oct 19, 2009 | 06:58 PM
JayT's Avatar
Bye Bye CL!!!
The members on the forums that switched from honda MTF used Syncromesh FM... I am running it as well
Old Oct 19, 2009 | 07:07 PM
I just changed mine this past weekend with the latest Honda MT fluid (2.3 qts.). It was like $8.43 per qt. The label has a green background, and states that it is 'New and improved for Honda vehicles'. The shifts felt smooth.
Old Oct 19, 2009 | 08:57 PM
civicdrivr's Avatar
FYI the GM Synchromesh found at dealers is the same as Pennzoil Synchromesh found at your local parts store, its just rebranded.
Old Oct 20, 2009 | 12:16 AM
monkeybutt's Avatar
Tried new Honda fluid and GM Synchromesh FM. I now have Amsoil manual transmission fluid and it is marginally smoother shifting than the others for me.
Old Oct 20, 2009 | 09:45 AM
Joe5.0's Avatar
TQ > MPG
I have used the old formula Honda stuff, the GM syncromesh, and the reformulated Honda.
I noticed a drastic improvement from the old Honda formula to syncromesh, but no significant difference when I went from syncromesh to the new Honda formula.
I am going to stick with the Honda stuff as it seems to last a little longer before it starts to break down, and the cold shifting was a little better it seemed.
Old Oct 20, 2009 | 11:40 AM
fuzzy02CLS's Avatar
I use the new Honda fluid. I really saw no difference. But it's doesn't get cold where i live.
Old Oct 20, 2009 | 01:32 PM
fsttyms1's Avatar
You can get any Syncromesh fluid (GM, Penzoil, BG ect..), just make sure it says "Friction Modified" You can get the Penzoil brand from most parts stores. Ask the guy at the counter.
I put it in my 6 speed after trying the "Improved" honda stuff and noticed a difference in cold shifting and less notchyness
Old Oct 20, 2009 | 02:05 PM
MrHeeltoe's Avatar
Former Sponsor
I'd stick with Honda fluid. All that stuff is really good. Honda Chemicals are the bomb but you'd never really think so.
Old Oct 20, 2009 | 04:45 PM
civicdrivr's Avatar
Im running the new Honda MTF now.
I used to run the Pennzoil Synchromesh in my Civic and it was great. It wasnt notchy at all.
You'll be fine with either one. The synchromesh will help mask so notchiness though.
Old Oct 21, 2009 | 03:59 PM
Elijah J's Avatar
thanks to all. Im gong to get the new GM Syncromesh with friction modifier. Its semi-synthetic(only difference from the old gm syncromesh) and thats really my only question. Apparently, the honda fluid is not synthetic. Any harm in using the semi-synthetic? It does get balls cold where I live.
Oh and on a side note, if I want to swap the clutch fluid to something that will be better in cold weather, what brake fluid is recommended?
Old Oct 21, 2009 | 04:11 PM
civicdrivr's Avatar
Old Oct 21, 2009 | 04:17 PM
Elijah J's Avatar
Confused? Or did I misspeak?
Old Oct 21, 2009 | 04:21 PM
civicdrivr's Avatar
I misread For some reason I thought you were asking what brake fluid to use in the tranny.
Yea, Im retarded.
Id just use any Dot 4 fluid. Water is brake fluid's enemy. Keep water out of the lines and it will be happy.
Old Oct 21, 2009 | 04:52 PM
StreetKA's Avatar
i just got back from associated auto parts and i asked them for royal purple synchromax manual transmission and they have to order it its like 17$ a qt part number 01512 jeeez i think ill get gm synchromesh lol
Old Oct 21, 2009 | 09:29 PM
Elijah J's Avatar
is it synthetic or not synthetic?
Old Oct 21, 2009 | 09:31 PM
Elijah J's Avatar
will someone please just tell me if the trany fluid theyve used is synthetic.
Old Oct 21, 2009 | 10:00 PM
anthracitecl's Avatar
After i put "new improved honda fluid" i didn't feel much differences.
and i switched to gm syncromesh i felt differences.
by the way here is part # 12377916
Old Oct 21, 2009 | 10:21 PM
Elijah J's Avatar
THANK YOU! That answers my question!
Old Oct 21, 2009 | 10:35 PM
Elijah J's Avatar
To summarize and in case someone else is out there looking to know WHICH GM Syncromesh to use, part #12377916 is the semi-synthetic new version. Its the one I bought and will use tomorrow. I suspect improvements and will leave feedback comparing it to the new honda fluid and Amsoil. Thanks again anthracitecl for confirming my suspicion.
Old Oct 22, 2009 | 01:38 AM
Jacobpockros's Avatar
I think the proper thing to do would be to stick with the New improved Honda fluid that they recommend. It will conserve your transmission in the long run. To me, this GM fluid just seems to be resembling a turbo on a motor, it will perform like a champ but will wear all the parts out faster than they were meant to.
Old Oct 22, 2009 | 05:33 AM
StreetKA's Avatar
its synthetic but today i will get gm synchromesh it wont be a big deal beetween royal purple and gm only price...
Old Oct 22, 2009 | 05:39 AM
StreetKA's Avatar
how many qt do we need ?4 or 3?
Old Oct 22, 2009 | 06:37 AM
Costco's Avatar
FYI, the Pennzoil Synchromesh isn't the same as the GM synchromesh. The GM stuff says "Friction Modified" which is supposed to be better for LSDs. I think in some areas they rebranded GM synchromesh to ACDelco Synchromesh which is the same thing even though the part numbers are different. If it matters though I noticed a huge difference in my Integra going from Honda MTF to Pennzoil Synchromesh, but it wasn't an LSD tranny
Old Oct 22, 2009 | 08:19 AM
civicdrivr's Avatar
Get 3 quarts, but only fill till the check hole.
That is correct, but I never said the Pennzoil was the same as the Friction Modified GM stuff, just the regular "old" version. I should have mentioned that little tid-bit though since out cars do have an LSD.
Old Oct 22, 2009 | 08:23 AM
womey's Avatar
Not 4 Wheelin Anymore!
I used Amsoil and the recommended 2.3 quarts is what you should add. I added 2 1/2 bottles thinking the check hole would drain quickly, WRONG! That stinking thing takes forever to drain...
Old Oct 22, 2009 | 11:24 AM
Elijah J's Avatar
I also used amsoil. not impressed. its been 15k since I put its back to notchy. We'll see if gm is any better. ... I will plug amsoil for their motor oil though; that stuff rocks! especially in cold weather!
+1 for amsoil motor oil but pass on the mt fluid imo
Old Oct 22, 2009 | 02:30 PM
StreetKA's Avatar
i just asked GM dealer about the new transmission fluid its 14.08 + tax for a qt its expensive too... and they dont have it in stock... i have wait one week or just go with honda stuff... i have time but i expected price in 8-10$ range
and its really hard to believe that GM's stuff is better than honda's
Old Oct 22, 2009 | 04:43 PM
it's GM for Christ sake! Come on people, we all know they can't do anything right anymore, hence why we keep needing to bail their ass out so they can make even more shitty products! :shakehead
I'm gonna go with a big :thumbsdow on the Fluid.
Stick to what the people at Honda/Acura recommend, after all they WERE the ones who designed the cars....
Old Oct 22, 2009 | 08:36 PM
LIPPSTUH's Avatar
Unregistered user
ummmm... no.
both are good, just pick one and put it in. sheesh.
Old Oct 22, 2009 | 08:52 PM
Rajca's Avatar
^x2. like honda cant built a lasting auto trans. ppl still buy the cars.
gm fluid has been proven to work for thousands of miles and years of use.than why not use it?
