Motor mount replacement
Old Aug 9, 2006 | 10:09 AM
fuzzy02CLS's Avatar
I need to know how hard it is to replace the mounts & which ones need to be replaced. The side one is leaking. The others look ok to me so which ones should I replace. I can get them all for like $300.
Are the mounts for the 6mt the same as the auto? I know the 6mt had an additional mount, but is it an engine mount or the shock absorber thing?
I looked at the parts websites & see the diagrams & seen the pics when I searched. I'm not filling them, just want to replace what's needed.
Old Aug 9, 2006 | 04:49 PM
TallyCL-S's Avatar
about::blank
I did not know the side mount was fluid filled, I thought only the front one was hydraulic? When mine goes I am going to do what CleanCl did and fix them with poly.
Old Aug 9, 2006 | 05:30 PM
CleanCL's Avatar
replace the front and passenger side, if one is broken, the other is too.
part #s for the manual only:
front: 50800-S3M-A01: $80.98 (has a new part #: 50800S0KA82, you can use either, you will get the new one regardless)
passenger: 50820-S3M-A81: $46.99
order from oemacuraparts.com by clicking "oem parts catalog" and entering in the part #s i gave you.
Old Aug 9, 2006 | 05:42 PM
Louie11's Avatar
your car must be an 03'. Are you out of warranty? I just had my front replaced last month under warranty. I have the 7yr 100,000 extended though.
Old Aug 9, 2006 | 11:09 PM
Allout's Avatar
Blown is Best
What CleanCL said
Typically the front one goes first and takes out the side mount that holds the nose of the motor.
Old Aug 10, 2006 | 06:01 AM
sob4681's Avatar
SOB type-s
Mine went too, all was covered under warrenty
Old Aug 10, 2006 | 07:40 AM
acurapimp504's Avatar
if I bought mine used. do i have a factory warranty? cause my motor shifts around alot. I would love to have them checked and/or replaced for free
Old Aug 10, 2006 | 08:19 AM
fuzzy02CLS's Avatar
Cool thanks.
Question... the side mount part # brings up several applications. Would any of them work?
So how hard is the front to replace? Do I have to lift the engine?
Old Aug 10, 2006 | 09:14 AM
CleanCL's Avatar
yup. their all the same mounts, just showing which cars utilize it.
i think you need to lift the engine up, you can use a floor jack and a p iece of wood to get it up to relieve pressure on the mounts.
Old Aug 20, 2006 | 06:36 PM
fuzzy02CLS's Avatar
I only got the side mount. I didn't see spending any more $$ on the front or rear mounts cause they seemed ok to me.
For anyone who does the side mount themselves. GET AIR TOOLS! The bolts that hold the engine bracket & the mount were REALLY stuck on there. Had to use a breaker bar plus the air to get them off. There's no way just a rachet is going to get those off. Once the bolts are out it's easy to replace. You will scratch the paint in the engine bay. I don't see how you wouldn't. You have to twist the mount in different angles to get it out. Once you get the bolt out it's a 10 minute job.
You have to unbolt the cruise amp - 3 10mm bolts, & set it aside
Next you need to take out the big bolt going through the mount. - 1 17mm bolt
Next unbolt the mount & the engine mount bracket to the engine. - 5 14mm bolts
Wiggle it out
Wiggle the new one in.
Reverse directions.
Old Aug 20, 2006 | 07:05 PM
typeR's Avatar
Wiggle it out
Reverse directions.
i think if you just jacked up the motor alittle, you'd have been able to get the bolts out no prob...i did it a few times with a standard socket wrench
Old Aug 20, 2006 | 08:45 PM
fuzzy02CLS's Avatar
Wasn't a problem since I had air. 51K miles didn't help I'm sure.
Old Aug 21, 2006 | 01:11 AM
Titand19's Avatar
East Coast Boost.!
i will jack up the engine
Old Aug 21, 2006 | 07:33 AM
fuzzy02CLS's Avatar
How can jacking the engine help any? It's still held in place by the front & rear mounts as well as those shock mount things. I don't see how you would be able to jack it up, or why that would make the side mount any easy to get the bolts out of. The side mount is a sold piece bolted to the engine, & the body.
Old Aug 21, 2006 | 07:39 AM
GreenMonster's Avatar
You're not really jacking up the engine since it's still held in place by the motor mounts...
What you are doing by jacking up the engine slightly, is removing the tension/weight of the engine off the motor mounts so that you can slide 'em out easily.
It's like trying to move a carpet in a house without removing the funiture... remove the weight of the furniture, and the carpet is easy to remove
Old Aug 21, 2006 | 11:51 AM
Titand19's Avatar
East Coast Boost.!
good analogy
Old Aug 21, 2006 | 01:30 PM
quicksilver10101's Avatar
i got my front one replaced under warranty a few months ago and its already shot...is there any stronger aftermarket mount available?
Old Aug 27, 2006 | 07:37 PM
JadeFox's Avatar
yay! for SRS xtension
Acura was trying to blame my trans slips on a loose front motor mount...are they talkin poop? when i brake, even very slowly, i come to that stop and get a good lil jerk...???
Old Aug 27, 2006 | 08:46 PM
typeR's Avatar
Originally Posted by Allout
honestly id say vis versa
Old Aug 29, 2006 | 08:30 PM
belcom's Avatar
09 TL SH-AWD
you know it's funny I also was told my motor mounts are screwed and they said we'd have to fix them first, before looking into the slipping tranny. they said the mounts might be causing the problem.
I did order them and have them sitting here. I have to install soon but I don't think I'll be doing a DIY. Who the hell knows how to fill that thing and where does that vacuum line go and do
bnaritomi
Feb 17, 2016 03:22 AM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
